robbie2883 »
https://forums.nicoclub.com/robbie2883-u41470.html
Sun Oct 25, 2009 4:09 pm
well guys....i've asked enough questions...thought i'd share the mess i've been dealing with and where she's at now.
guess i'll start from the top. so when i got this car there was ALOT wrong with it. and by ALOT i mean ALOT. so far i've spent over 50 hours rewiring this car just so i don't burn to the ground driving down the street. i find it hard to believe that someone could talk sooooo much s*** to me and actually have the balls to tell me not to ****** rig the gauges in the car i gave him then hand me this piece of work. first things first...here's some of the before shots.......
this is the kind of wiring i've been dealing with. notice the HUGE main UNFUSED power wires bolted together with nothing more then a loose rag keeping them from shorting to ground.
and the power wire going through the firewall with a grommet that's way too small rubbing against bare metal hole, and the smaller one running between the main grommet and metal? oh..and that one is for the amp. so he ran a power wire from the back of the car to the front to hook up to the main wire going to the battery which is in the truck. instead of jsut running the amp wire across the trunk to the battery.
wire ties for radiator mounts
half asses twisted together and taped wires for the fan controller (they melted by the way from arcing against each other)
gauges that didn't even work cause something as simple as power and ground not being hooked up right
not to mention numerous other wires all being twisted and losely taped (including main ecu power wires and sensor wires) no wonder this thing ran like s***
it only made 180 whp on the dyno when i first got it......
here is a simple after pic since doing alot of rewiring. alot more has been rewired correctly since this picture too
new radiator mounts
now we get to the fun...where i've made a mess of things. had to do an oil change and the filter is in such a pita place that i decided to do an oil relocation kit and cooler at the same time so i only have to get under there once. needed to pull the manifold for a radiator breather anyway.
just waiting on the thermostat to get here so i can put it in and the oil system is done
some of you may have already read my timing belt thread but here goes anyway...while i had it apart i decided to take a look at the timing belt b/c i had a sneaking suspision something wasn't right....well guess what...i was right...several things were wrong....first off the belt was WAAAAAAAY too tight. so tight the idler pulley took the top layer of the belt off and caked it on the pulley. next there were some metal shavings on the tensioner pulley. i took it off and noticed the conical washer was on backwards. my guess is that let the tensioner pulley wobble which is bad for the internal bearing. last but not least the crank timing gear was on BACKWARDS!!!! this means there was no timing mark to line the belt up to when installing. WTF!!!!! oh...and the tensioner pulley has groves in it i can feel with my fingernail...all from the belt being too tight. again...WTF!!!!
major mods on the car are
wisco pistonseagle rodsjun crank collarn1 oil pumpoem water pumpgreddy ic and intake manifoldSpearco meth injectionsetrab oil coolerApexi PFCGreddy 60mm boost + EGTInnovative lm1 + lma3gr+ pro coiloverses subframe bushingsDIF billet differential bushingsz32 30mm front brakes
waiting to be installed or in processpower enterprise timing beltapexi avc-rgt35rtial 44mmgreddy radiator breather w/ WR overflowupgraded fuel lines and billet top feed rail with supra 550's greddy catch can
i'm sure i forgot some stuff....oh yeah...also had some stuff powdercoated!
