Not at all. It has fully unrestricted independent flow front and rear via the louvered wheel arch shield and of course the under grille opening in front (see other picture looking into the bumper cutout).FarFetched wrote:If you mount it in that location, you would have to run auxilary fan to keep air flowing trough it!I have researched before I got it on my car!
Not sure??maxnix wrote:... Where's the link, Rex?
No image on my browser. Maybe pop-up blocker killed it.Rex wrote:
Not sure??
If you click the image (above), the larger version opens in a new window (on most systems).
You can edit the picture's description, by viewing the picture and then clicking "Edit Photo" on bottom right (blue banner). Then "Edit title for the photo" about the 5 line down.maxnix wrote:No, editing the picture's description at Member's Rides.
Don't know why some pictures show and some don't, though. You know, the way you post them Rex, they never show.
Falkdesigns wrote:Good stuff. I'm thinking of one of these JEG'S made by Flex-A-Lite, so I know they make good stuff. Plus we get the hook-up with Jeg's since we do all thier race suits. I was thinking of this one 400-3812, since I've never heard of a transmission problem on the Y33, I figure it's gonna be good enough. The other one I'm thinking of is B&M polished supercooler 130-70265, also from Jeg's.
That looks just like the OEM cooler, except prettierRex wrote:Here's a Moroso unit that's both a cooler and a filter
Do you mean the pictures I posts never show up? You just see a red x? Really?
Brian, what browser are you using and do you have extrernal images turned off?
Polished is less efficient than black.Falkdesigns wrote: I think I'll go for the polished B&M.
Here's my concern with your set-up. What happens at idle? I completely understand the air flow from the front intake to the wheel arch but at idle with the car stopped??maxnix wrote:Not at all. It has fully unrestricted independent flow front and rear via the louvered wheel arch shield and of course the under grille opening in front (see other picture looking into the bumper cutout).
The main advantage of this location is is is well shielded form stones and does not transfer heat to any other radiator. It's cooling flow is its own.
Modified by maxnix at 4:10 PM 3/10/2005
