Stillen Catback Exhaust
Speciality Z 3" downpipes/test pipes
Jim Wolf Tech dual pop Intake System w/Dual MAF
AMS MaxFlow Manifolds
Suspension:
KAZAMA Tension Rods
TEIN Coilover kit w/EDFC
Stillen Front/Rear sway bars
Engine Electronics:
A'PEXi S-AFCII
HKS Turbo Timer
Greddy Boost gauge
HKS EVC 2-Stage Boost Controller
Motes 16-Option Control Unit for 91-octane/E85 Fuel
HKS Twin Power DLI Ignition
Engine ReBuild:
Engine Block Work (torque plate, bore and hone, clean out water passages, check block for defects), new engine gasket set, main and rod bearings, HKS Internal Waste gate actuator, ARP rod bolt kit for OEM rods, ARP Head/Main Stud kit, OE Hydraulic lifter, Full Cylinder Head Repair (new valves, new oil seals, new guides, welding and redecked), Z1 Motorsports GT675RS Turbo Kit, GREDDY Front Mount Intercooler, Wiseco Coated 88mm Piston SET, ECU Reprogram, NEW OE EFI Harness, Injector Dynamics 1000cc Injectors with WINFactory Top-Feed Fuel Rail Kit, Koyo Full Aluminum TT Radiator, NGK Iridium Spark Plugs, Timing Belt (tensioner, water pump, water pump gasket, thermostat, coolant bypass hoses, variable timing control O-Rings, variable timing control springs, camshaft seals, crankshaft seal, crankshaft sprocket spacer rear, idler pulley), Redline 20W50 Full Synthetic oil, K&N Oil Filter, clutch slave cylinder, ALL recent Z1 silicone hoses including Z1 PCV Hoses, Secondary Switch-Activated Fuel Pump, HKS SSQV Blow Off Valves, Optima 800CCA Battery.
Interior:
Momo Steering Wheel/Momo Shift Knob
All Memphis speakers
VALOR NVG-670wt Headunit (touch screen not currently working)
JL Audio Amplifier
Exterior:
'99 JDM Front Fascia
300ZX Kaminari Wing w/LED Light
All NEW OEM Nissan window moldings
'99 JDM Taillights
Smoked Corner Lights
CATZ HID Headlights
Volk Racing SF-Challenge 18/9 & 18/10
Nismo 60mm Wheels Studs
BFGoodrich G-Force T/A KDW 235/35ZR18 90Y & 275/35/ZR18 95Y
Driveline:
South Bend Extreme Clutch 850 lb/ft torque
SS Clutch line
RPS Flywheel
NEO 75W90HD Synthetic oil
Z1 Aluminum One-Piece Driveshaft
Unorthodox Crank pulley w/belts
