Maxned3c »
https://forums.nicoclub.com/maxned3c-u249135.html
Thu May 28, 2015 12:36 am
Hello all this is my 90 nissan 300zx
Jdm tt swap
Z1 gt535r turbo kit
Nismo 615cc injectors
Cx-racing front Mount intercooler and coilovers
Megan tension rods
Hks blow off valves
Hks hi power exhaust
Z1 down pipes and mid pipes
High flow cast manifolds
Xtd stage 2 tt clutch with 11lbs fly wheel
Inland empire 1 piece aluminum driveshaft
Circuit sports drilled and slotted rotors
Stop tech pads
Aem boost, air/fuel, oil pressure gauges
Circuit sports short throw shifter
Work miester s2r wheels
All emissions and coolant hoses deleted
Z1 titanium gauge trim rings
Cx-racing aluminum dual core radiator with electric fan and aluminum shroud
Gates blue racing timing belt
Z1 heavy duty idler studs
Heads have been completely rebuilt and machined
Cometic mls head gasket with arp l19 head studs
Power steering and oil coolers
running 11lbs of boost. It's still In need of a proper tune for more boost. Turbo swap with a 5sp Na trans, walboro 255 fuel pump, chipped tt ecu.
Coolant lines under intake Egr and tube Aiv Air conditioning all deleted. I got few improvements and completions to come.
