My new project
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
No, that WAS a brand new one... I suppose it could have been sitting on a humid shelf in japan near the sea for a few years, but still.
You can't rebuild them, they don't flow well enough (just a modified stock), and just too expensive for what you get. Not my cup of tea.
Like I said, I can get better for less than half the price.
Just IMO.
Sideways s12
Car: 84 turbo s12
Ordered a new safc2 need to order the fpr which i will do soon then I can put my injectors in and my maf and turn up the boost!
float_6969
woot!
Sideways s12
Car: 84 turbo s12
You think I still have to change to a different fpr? I'm running the sr stock unit with the safc I can pull fuel from idle and lean it out a bit to keep it from stalling.
Sideways s12
Car: 84 turbo s12
safc and n60 maf are on and now my issue is I randomly go rich while cruising. The ecu is not reading that I'm removing fuel only at idle it reads it everywhere else. Any ideas?
boost_boy
How rich is it at idle and cruise? And how close is the AFM to the turbo? If it's too close, you're going to have all sorts of weird issues.
Sideways s12
Car: 84 turbo s12
At idle it's at 11 sometimes 10 cruising is 14 -15 then drops to 10 randomly then clears up then repeats maf is roughly 4 to 5 inches from the turbo because I don't have much room over not enough for 10 inches anyway...
boost_boy
Your air flow meter is just too close to the turbo, brother.
Sideways s12
Car: 84 turbo s12
Ok I'll see what I can do to move it elsewhere
Seishuku
On my SR, when I still used a MAFS, I had it like 2-3 inches from the turbo and never had issues like that... Is the N60 MAFS more sensitive to turbulence?
Sideways s12
Car: 84 turbo s12
Iono but everyone has told me that they need to be at least 10 inches away even when I was playing with the single cam
float_6969
Yea, it sounds too close. Also, you have to have an air filter on there too if you don't have one.
Sideways s12
Car: 84 turbo s12
well I talked to Dee and we came to the conclusion that the 02 sensor is prolly bad. Also Float I do have an air filter on there I prolly need a new one of those as well as the one I have is super old and dirty. going to replace the 02 sensor tomorrow after I replace the fpr again.
Sideways s12
Car: 84 turbo s12
I replaced the o2 sensor it smoothed everything out but the problem still exists
Sideways s12
Car: 84 turbo s12
I don't know what to do....
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
is it possible your SAFC2 isn't on the correct settings?
Sideways s12
Car: 84 turbo s12
We looked it up on here I have a z32 maf and I was told 2 different settings for it currently its a 2in 7out
float_6969
I'm pretty sure 2in7out is right for an N62. Are you 100% sure it's an N62 and not an N60? They look identical externally.
Sideways s12
Car: 84 turbo s12
Yes I have both. And im wondering if its the CTS and TPS and possibly injectors. While cold the motor reacts to adjusting the safc if I add fuel the idle.goes up if I take out fuel the idle.drops back down but once warm it doesnt react at all it stays at 11 on the wideband. The reason I think the tps is one of the problem is because at certain positions the car starts to sputter and when revving to.keep it from dying there is a delay between the pedal going down and the motor revving up. Also I.still cant explain the random richness while cruising.
Sideways s12
Car: 84 turbo s12
So I replaced the cts today and that seemed to help a little but the problem still exists
sjbsuperman1425
CA18DET
have you replaced your oxygen sensor? I had all sorts of problems when in went bad and it never threw a code..
Sideways s12
Car: 84 turbo s12
yup that was the first thing I replaced. Also I have nistune on its way so hopefully that helps.
In other news I spanked a 90 turbo celica the other day and by spanked I mean SNAPPED THE f*** OFF! lol I love the ca!
MorrenCraige
Car: BMW 7
Cool to see some S12 stuff going on, hope you can get her going good soon!
Sideways s12
Car: 84 turbo s12
Thank you and I should be getting nistune soon.
sjbsuperman1425
CA18DET
I just started my car and have nistune and I will say, it's going to be terrific for diagnosing. The amount of information I can see just at idle is awesome.
On that note, if/when you get nistune, do you plan to keep the new maf on or do you have a stock CA one you can throw on there just to make sure you have a good platform to work off of?
Sideways s12
Car: 84 turbo s12
I am keeping the n62 on because I dont have a stock 18det maf the maf I was using before was the 18et maf they look similar I accidently sold the det one to a fellow s12er.
Sideways s12
Car: 84 turbo s12
In other news I picked up my nistune ecu last night going weds to install it and hopefully get a decent tune.
Sideways s12
Car: 84 turbo s12
Ok nistune ecu installed but couldnt get a base tune on it as the laptop died =/ so sometime this week I have to.go.back so we can tune it.
Sideways s12
Car: 84 turbo s12
Nistune installed and tuned 5psi stock fuel and she pulls pretty good! Powerband is linear not spikey like most boosted cars but I attribute that to the cams it has a nice bottom end along with a great top end.
In other news I had a civic try me on the freeway after I got tuned you can guess what the outcome was lol...
krazy skwerel
Car: 1989 240SX Coupe down for the count
2005 Honda Accord
1974 Ford Mustang II
He'll yeah s12 power!!!
