Path of least resistance ftw!
I would also add a few minor things into that cost analysis. You really should get a bunch of different colored wire at different gages for your project. When i wired everything up, all the sensor output wires had a different color wire. I then made a wiring diagram of my engine so if i ever had any problems i could just go back to my diagram and figure out what does what. You dont know a nightmare till you have an electrical issue with 20 different strands of black wire. If you really want to go baller, you can pickup the bulk wire that DIY autotune sells for their kits. Its colored, and each wire is labeled as to what you should use it for.. Pretty sweet, but out of my price range and unnecessary.
Im telling yah, if you really want to make your life simple pick up the relay board for MS. Its going to add 88(was 70) dollars to your full MS price if you get a prebuilt one(however with how easy it would be to solder this thing up you could get away with the kit and a radio shack soldering iron). However, at basically a 100 bucks you really have to think about how lazy you really are, its not needed at all but ensures a clean and reliable wiring job. Check it out
http://www.diyautotune.com/cat....html
You hook all your engines wires to it(the board is labeled, ie. CLT, CLT GND, ect), then run a constant 12 volt, a GOOD ground( i would suggest running multiple grounds), and your 12 volt ignition to the relay board. Then you simply run the connector wire from the relay board to the MS unit in your car.
Modified by 480sx at 9:30 AM 4/26/2008
