C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sat Jun 25, 2005 10:12 am
sanoill: while I am generally the first to argue backpressure, this isn't a manifold designed to try and provide a perfect backpressure scenario. For the most part, it seems each runner maintains the inside diameter so there should be little effect on backpressure from one runner to the other. THe only other factor then, would be the backpressure the turbo itself provides and perhaps the exhaust system behind it. But neither of those will be affected by the manifold's design. The way the #1 runner meets is directed at the collectoris about the only thing I would question froma flow standpoint, but the manifold will direct the airflow into the turbo as intended and do a decent job. My only gripe, which I previously stated is the mani's longevity.
I give props for trying it. I would have tried to source all stainless parts if I were intent on doing it though. To all their own I guess...
