My LS1 S14 build thread
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
Joe
finally opened her up tonight, so far so good. lots of varnish in oil areas but no sludge. all water passages look amazing. no signs of corrosion or anything. water and oil pumps look good. gonna do a Katech oil pump tho. cheap insurance.
Joe
crossmember notched and back in.
disclaimer: i only have a gasless 110v mig welder. so i apologize for the crappy weld quality :lol:
hopefully oil pan will be here in the next few days so i can build the mounts and finally drop her in.
-ExCesS-
Car: 00 Sentra / 95 240SX
lol me again, asking questions before you get too far ahead. Is that the stock crossmember? (still learning about the S-chassis lol) and do you have pics of it before the changes?
Joe
that was my r33 crossmember. its better to use a RB20 or RB25 crossmember because the engine mounting pods are about 1.5 inches more forward than the KA/SR crossmembers. it gives you more clearance for your header on the drivers side, and makes fabricating engine mounts easier
heres it unmodified, and upside down
WDRacing
Joe, you should get picks before, during and after bro...you suck at this...lol.
Joe
i dont take pictures when im working on stuff, it distracts me lol
WDRacing
I'd suggest a video camera, but then we'd catch you making out with your boyfriend
Joe
youd watch me drink beer and get nothing done for hours on end
Abdo
Car: S13 RB25DET
Kamin wrote:youd watch me drink beer and get nothing done for hours on end
LMFAO too bad its true!haha! j/k m8!
0wn3r
Car: 1997 Nissan 240sx SE track car (SR20DET, caged)
was the RB that disappointing?
Joe
thanks for the warning but im going to be moving this engine back as FAR as i can.
cnichols
Car: 96 Nissan 240SX
99 Infiniti Q45
93 Ford Fastiva
Just remember that the MAP sensor, Knock sensor, the brake booster line, and I think the Cam sensor are all behind the intake manifold. I left myself some room so that I could work on these things without having to unbolt the motor and hoist it forward.
Just something to think about. Being able to work on the car was my main concern when placing the motor...not getting it set back an extra inch or two. But, hey...that's just me.
Joe
ya i know, thanks for the reminder haha
when i say as far back as possible, i actually mean "i will sacrifice the ease of ability to get to those things on the back of the manifold so long as i dont have to cut my hood"
p.s. rb is finally sold
custom cam is being made
truckload of parts arrives next week.
cnichols
99 Infiniti Q45
93 Ford Fastiva
I didn't cut my hood.
Joe
oh i know, most people dont have to. just saying
Joe
parts started showing up.
clutch master, headers, and thanks to larry's engine and marine an oil pan i can borrow till my real one shows up. thanks Larry I owe you one.
clutch master and half-made adapter bracket. it will be finished tomorrow. thats the wilwood master cylinder with the nissan rod/U bracket for the pedal. scarily enough it fits perfect in the wilwood master.
front on sump GTO oil pan. thanks again larry!
headers. i dropped the engine in the bay for the first time really quickly to get an idea if they will work and i dont think they are going to work...oh well i guess ill just cut them up and make them work haha. i wont know for sure till the engine is mounted this weekend. so stay tuned
tomorrow the clutch and stainless steel lines should be here for the clutch system. flywheel should be back from the resurfacer too.
cnichols
99 Infiniti Q45
93 Ford Fastiva
I stand by my recommendation to get the Hinson Headers and a driveshaft from them as well. Then just figure out where the motor needs to sit and you instantly save yourself who knows how many hours of headaches trying to hack together some frankenstein headers.
Also, a note about the clutch U bracket. Mine was too short. I've also seen the stock ones break (mine for example, when the SR was in it)
I ended up fabbing a new one out of stainless that was longer.
QuickerThanU
Car: 98,95,94,89 Nissan 240sx
You fa.ggot hurry up with this swap. J/k gj and i plan on doin the same swap in my s14 and will use this as a guide
Joe
chris not paying $800+ for something i can make for less than half of that haha. this swap doesnt need to be show car clean. its a racecar
cnichols
99 Infiniti Q45
93 Ford Fastiva
I competely understand where you're coming from because I made everything else for my car.
But, it was worth it time wise for me. The Hinson headers are stainless, the welds are great, and they fit. Time is money! :D
I just refuse to ever use any exhaust components that are not stainless.
Joe
doesnt matter in arizona we dont have rust haha
WDRacing
Kamin wrote:doesnt matter in arizona we dont have rust haha
Exactly...not to mention mild steal coated with ceramic works just fine for this kid.
Joe
its been slow going, im thinking way too much about the mounts. just need to build them and be done. I also had to renotch my crossmember, needed the engine back another inch. ill get pics of that and of the mounts once they are 100% finished.
the mounts are just tacked together right now, a very simple version. (yes i know the engine is twisted a little. the mount isnt attached to the crossmember yet. just resting on it.)
the best part
the hood closes :lol:
they are gonna remain tacked together till the clutch arrives and i can put the transmission back on and get the final position for the engine. i think its very close tho.
300hp owen
Car: '04 STI and '87 FC LS1 swap'd
NICE NICE!hey once you get a big fat 4" elbow and some CAI piping on that throttlebody, you might have some hood fitment issues, its always close so you may need to think about how quickly you can angle the CAI downwards away from the hood and how short to keep the elbow at the TB so it doesnt stick forward any more than necessary.
that engine bay cleaned up very well, looks so simple and basic in there now, its nice that the LS1 setups dont require a lot of auxillary stuff in the engine bay to run them, it makes wrenching on them a lot easier.
awesome progrress man, now FINISH UP!!!!!!!!!! lol.
Joe
hehe i know, last night i put the hood on and checked clearance there. ive got about .25 inches clearance so it should be JUST enough for the elbow.
and if it hits, its hitting the skeleton, not the hood itself so ill just notch it
300hp owen
niiiiiiiiiiiiiiiiiiiiiiiice, good work on the fitment, ya gotta love DIY LS1 mounts!props!
Joe
oh my god an update! haha sorry again for the lack of them. ill take a ton of pictures as soon as the engine is mounted completely for the last time lol
the renotched crossmember.
my over engineered transmission mount
patriot extreme dual springs
p.s. if you own a crane on-engine valvespring compressor, replace the turndown nut. mine stripped on the last pair of springs lol. luckliy i had a spare. dont ask me how i did
Joe
engine in the car for the first time unsupported. gonna start building the exhaust on monday
Logan76
Car: Junk
Thats slick as hell, lookin' good man.
Picolini
Car: 89 240SX FB DEAD, 92 Beretta GT DEAD, 91 Camaro RS DEAD... carless!
That's awesome man! I bet it's nice to have it sitting in there all on it's own. Good luck with the exhaust!
Return to “Hybrids”
