Jacko3 wrote:With almost 250K---original engine and trasnmission, my little nissan is having issues with engaging in the 5th gear--I have to try to engage it, at least twice before it engages fully---it does not grind or make any funny noise---once it grabs, its just fine. All the other gears work just fine and they grab very well. One person says my clutch is going out and another person says, the whole manual transmission may need to be replaced. Little nissan is 5-speed.
Used manual transmission is about $350. New Autozone clutch kit (Duralast) and installation will cost me about $200.
Problem with buying used transmission is that the used transmission may have issues with its own gears as well as I don't know how it has been driven by previous owner.
Any take on what you think I should do, or what you think the issue really is with my transmission?
Jacko3
I will repeat what my old 1980 VW diesel Rabbit mechanic told me in 1994 when its oil pump failed at 246k miles.
TIME TO GET RID OF IT.
If you spend the money to repair it & then something else fails you will keep throwing money at it.
A new vehicle comes with all new parts and a warranty Just my $.02
Telcoman
