orijin »
https://forums.nicoclub.com/orijin-u102306.html
Fri Jul 23, 2010 7:30 am
I actually took my LED turn signals off recently, there was something about the LEDs were causing strain to my BCM according to the nissan dealership when i bought it in the my fuel gauge fix.
They were hyperflashing, and I just didnt feel like splicing or tapping into the light system of my nissan rogue. I wish there was an amp or fuse to fix the hyperflashing like other car companies but unfortunately for nissan they do not have any of it for them.
Ill just stick to the interior leds from now on, there was also a problem where when i applied the brakes during the day time my front flashers will go on, i really did not know the reason for that but it was caused from having the LED flashers in the front.
I still have the HID kit though and that doesn't seem to cause any problems. I recommend using oem lights as flashers, if you do not want to use the load resistors because it would seem it would damage the system's BCM eventually and will be a 2-3k repair at the dealership. Hope that helps.
And Jerry98vert, i know ebay lights are cheaper believe me i had them too and they will never be as bright as if you were to get some from v-leds (i do not work for them, nor get referral credit), i absolutely recommend leds from them although my license plate light one of the leds has gone out after a year, every other led light has been 100% fine though exception for that one bulb. They usually have 10-20% off coupon codes occasionally, just have to google it and they have a fanpage on facebook so you can know when the sales are, they had the HID light systems for sale for $65 at one point, and that is the same HID system I have been using since september 2008.
