My KA-T Build thread. Cage, turbo, fuel cell, more
TeeJay
Car: cars, pie, cars and pie
I must know more about what you did to your floor. How much head clearance did you gain? 1 or 2 inches maybe? Are you having clearance issues with the exhaust now?
S13FREEAAK
RyanAwesome wrote:great looking work so far! just a few things, the 2 parallel bars in the halo bar is extra weight with not much torsional rigidity. maybe just a diagonal bar? and the rear down tubes should of been mounted to the apex of the bend of the main hoop to support the bends. other than that, fantastic work. im not talkin out my butt either. i was one of the main fabricators for a 6 second chromoly drag chassis. did 50 percent of the tig welding and 60 percent of tube fitting and measuring.
Thanks for the advice. Yeah, this was my first cage. This cage was more for practice with our new tube bender. Sooner or later this cage will be cut out and I'll make a chromoly one. But thanks for the advice.
TeeJay wrote:I must know more about what you did to your floor. How much head clearance did you gain? 1 or 2 inches maybe? Are you having clearance issues with the exhaust now?
All together I probably gained 3 inches between doing the floor and solid mounting the seat.
I haven't done the exhaust yet. But it will more than likely going out the side.
RyanAwesome
Car: Murdered out coupe.
no problem man. if u need any more advice send me a pm. il be glad to offer up what i can.
WDRacing
This thread is 2 years old...why did you bump it? Do you have downsyndrome or something?
DMan II-40
Car: 1995 240SX SE
SR2OM0NSTER
Car: 1990 s13 HB S14SR Works
why'd you bump it? are you retarded or something? jokes on you. seriously, I didn't even check the date on it. (kinda like the rubber used to concieve you) I was looking for roll cage ideas. Good clean fun ey?
S13FX
Car: '69 l20b Dimeski :)
WDRacing wrote:This thread is 2 years old...why did you bump it? Do you have downsyndrome or something?
SR2OM0NSTER
oh boy, I forgot, one slip up and the supermods come out of their shells. cyberbullies.
WDRacing
SR2OM0NSTER wrote:oh boy, I forgot, one slip up and the supermods come out of their shells. cyberbullies.
I don't know why you'r harrasing me, you're the one that replied to a 2 year old thread because you can comprehend the date. I said my peace you said yours, now you're done replying to this thread and you're also done harrasing the staff. I'm all for screwing around...but I don't know you. So this ends here.
ThxWD
