I only had to drill one hole in the front but its because the coilovers are a mixture for different cars. It worked out and I will be modifying the sway bar mounts to work as well.yodawill2000 wrote:Did the Megan coilovers need alot of fabbing to fit ??
Jspout-It's a totally different car now..jspout wrote:I would love to have a manual transmission in this car. i don't think the stock transmission fully utilizes the power and dinamics of this motor. What kind of investment are we looking at? Time and money?
I can take photos. Finding the right spot for the pedal was a little tuff. I did have to bang the fender well to make room for the clutch master cylinder and I also had to extend the clutch pedal 3" because the location of the master cylinder was so high up the fire wall.boostAbear wrote:I wanna see how you mounted the clutch pedal. Must be fun with a 5 speed and coilovers on it
I kinda figured that you would have to do something to fit the clutch master in there, its a tight squeeze. Pics would be awesome!!Driftday wrote:
I'm guessing S13 coilovers plus lca, tie rods, tension rods, knuckle, conversion hub, etc. Congrats man!Driftday wrote:
Here is a photo of the front camber plate
I am still using all stock J30 parts. Its actually nice because it is still using the factory ABS too.thejapino wrote:I'm guessing S13 coilovers plus lca, tie rods, tension rods, knuckle, conversion hub, etc. Congrats man!
Here you go...thejapino wrote:Wait, doesn't the J30 have the shock attached to the spindle like Y33's? How'd you get around that? Drftday, details please. This has me all intrigued and s**t.
We are doing a manual swap on swimshark's j30 this weekend. We have done major car work before so it shouldn't be too hard but i was wondering if you could post up some pics of the pedal mount, the clutch master cylinder, and how you altered the transmission tunnel and fender well.Driftday wrote:
I didn't spend too much money but since I pretty much did this without any references, it did take a lot of my time.
Here is a list of stuff I pretty much needed.
Transmission (Z32)Custom driveshaftclutch pedal (cant remember)clutch master cylinder (s13)Clutch Slave cylinder (s13)Ebrake handle (s13)transmission bracket (For S13 but modified)SPEC clutch (Z32)
I think that's it. I probably spent $1,000.00 for entire project. The most time I spent on the project was figuring out the clutch pedal location and figuring out how of the transmission tunnel I had to cut to make the transmission fit right.
Are you having a driveshaft made for yours?swimshark wrote:Also what did you have to do about the wiring harness for the sensors on the manual trans? Did you have any difficulties with the rear transmission mount? I know the 300zx have a 3 bolt pattern on the bracket and the J30 has a 2 bolt pattern for the auto.
Thanks
