I guess it takes the computer/engine that long to respond and change over from the normal maps to the WOT maps. I'm telling you though, mine did the same thing.nkawall wrote:hmm that makes sense although when i floor it, it's still sluggish for about 3 - 5 seconds then it takes off
im a real newb when it comes to this i guest ill do a search on how to see how to check the ecu code. i have not cleaned the MAF ill try doing that. could it be a possibility the wires to the MAF are bad when i barley move the wire there I get some serious flocculation.yodawill2000 wrote:First step is to see if the ECU is throwing a code.Some dont light the Check engine light , like the knock sensor.Have you cleaned the MAF lately?Thats an easy one to eliminate.
Yes, clean that plug with electrical cleaner, as well as the MAS air flow sensor in the intake tract.nkawall wrote:is the plug that you have to clean the contacts on the one with the clip on it and no screws ?
Scott, I'm interested in your train of thought -- why was the MAS the first thing that came to mind in this case??gr8scott72 wrote:MAF is the first thing that came to my mind if it's a load related problem meaning that it is fine in idle but with a load (in gear) it has trouble.
Agreed, that's what I would think. This would be the case regardless of the load.yodawill2000 wrote:i would think at idle the MAF wouldnt cause much of an issue but on throttle up if the MAF isnt telling the ecu to increase the fuel flow to the injectors you would have a power loss issue.
