supadave »
https://forums.nicoclub.com/supadave-u72882.html
Wed Aug 08, 2007 12:39 am
im having problems with my 96 j30 stalling out in idle i could barely drive it to autozone i did a code read, knock sensor, bank 1 slot 2 ox sensor, low coolant temp sensor, while there i also changed the air filter and that seemed to be fine for a day but it is now wanting to stall out again in idle, could this be the MAF needing to be cleaned exc. how can i bypass the knock sensor to see if this is causing the stall, and what excatly does the knock sensor do. also if my car hasnt set for awhile its extremely fun trying to start.
