WDRacing wrote:First off, I'm sorry to hear your mani cracked...thats a real bummer. When I was learning to weld, I thought I had the WG pipe done awsome, turns out the weld looked beautiful, but had ZERO penetration on the mani side, so the pipe and WG blew off and were hanging from the vac line on the WG nipple...good times.
Bracing, well any metal that contacts another metal is going to increase or decrese that spot's ability to absorb, deflect or disperse the temperature. Bracing is usually used on a manifold where the runners were made out of a thinner walled material. The bends to the collector, added weight of the turbo and vibrations from the exhaust system really put some stress on a manifold. Let alone the tremendous amount of heat that its has to deal with. IIRC the supports go from the T3 flange to the actual head flange. If this is correct it's the best way to use a brace, because both metals should be the same thickness and neither is on the runner itself. The runners being the thinnest part, super heat, then cool..repeat all day. Having a brace on a runner...not somthing I would do unless I was cracking the mani where the runner mates up. A better brace IMO would be somthing to support the entire manifold in a verticle direction. Probably to a motor mount..
Reguardless, the mani should not have cracked like it did. Bracing or no...then again, I don't know how everything is together. If there is a pre-load on the downpipe or any part of the exhaust...the mani will crack very quickly. I'd definitly employ a flex pipe section.
Check out your exhaust, re-weld the cracks and press on.
WD
I got a better rookie welding story. On my first car, a 1983 Toyota Celica GT-S, I decided to make my own short shifter(seeing as how noone made one for it). I found a used lever at pick-a-part for $15.00. I completely took it apart and tried a few things, eventually coming up with a design that cut out a 2 inch section at the base of the shifter about an inch from the fulcrum and rewelded it together. It held for about 2 weeks when I had a run-in with some old VW beetle. We took off from a light and I pulled ahead immediately, only to shift to second and have the whole dame thing break off at the lowest weld. All this while my female passenger was laughing her *** off. And she continued to laugh the whole way home as I had to shift with about 1 inch of shifter. I got much more of a short shifter than I had anticipated. My dad later saw my welding work and laughed at it as well before fixing it for me. I leave welding to professionals now.
As far as bracing goes, even if you attach them to flanges, the runners will want to expand more than the brace since the runners see more heat. This would be more of an issue with stainless steel than mild steel as it expands more for a given temperature change, but whether or not anything will crack depends on many factors.
Heating and cooling in that of itself is not the issue. It's when different parts of the manifold heat and cool at different rates and to different temperatures at the same time. The most common problem being when the runners are hotter than the head flange, it tends to want to bow the head flange and the head flange will prevent the runners from expanding. This puts stress on the head flange and the collector. The other one is the wastegate tube(both before and after the wastegate).The header and exhaust will see heat generally relative to engine load but always see some level of heat constantly. Wastegates will be cooler while the WG is closed and then begine to heat up as it opens. How much it opens can also be a factor here. It's at a different temp than the manifold and the exhaust very often and goes through heat cycles at different times.
There is actually one concept I've heard about thin-walled mani's being less prone to cracking. The thinner walls have more uniform heat through the wall thickness and has less chance of cracking. Though, I'd speculate this is more in the runners themselves and would still require considerations for expansion. The concept seems somewhat valid though. Think of welding cast iron. It's generally thick and therefore prohibits the use of arc wedling as the local temperature at the weld gets so much higher than the rest of the part. Even a gas weld requires the part be heated up to keep temperatures more even and requires a long staged cool-down period. Too much of a difference in temps across such a thick part will cause the part to crack while cooling down after being welded.
