lrb_2000 »
https://forums.nicoclub.com/lrb-2000-u28436.html
Thu Nov 16, 2006 11:59 pm
So I got everything installed. I must have had some crazy leaks. I didn't change my setup at all, and it hit 15psi right away, which it previously was set at 10psi, so I had to lower the boost a little... the turbo spools like crazy now. I used all new gaskets, and metal ones for the turbo. Everything bolted up good without having to force it. Also, filling those motor mounts with the window weld helped a lot. The engine looks a lot more smooth, and doesn't torque as bad now.. I can kind of feel the extra vibrations in the car, but I have coilovers and such, so I don't really care. I hope it holds up this time. I'm going to get some videos next week probably.
