Hellion
Check out our site.
http://www.splparts.com
I suggest the following for a fully adjustable and an excellent handling 240.
SPL Tension Rods - $161
Tension Rods allow you to adjust caster, which affects steering response strongly. The pillowballs give quicker response and near zero deflection unlike a polyurethane bushing.
SPL Rear Upper Control Arms - $222
RUCA's allow you to adjust the rear camber. This affects road handling and tire wear. It also offers the same near zero bushing deflection. These arms allow you to adjust much farther than the 0.75 degrees offered by the whiteline kit.
SPL Rear Traction Arm - $222
Rear Traction Arms help to maintain suspension alignment and eliminate bump-steer associated with lowered suspension geometries. In combination with the rear toe arm it allows for a correct suspension alignment in the rear.
SPL Rear Toe Arm - $199 *SPECIAL NICO PRICING*
Rear Toe Arms allow you to adjust the rear toe. When you lower the car a significant amount with coilovers you'll notice that when you correct the camber you will run out of toe correction. With these rods you can effectively set your rear toe to whatever you like, no matter how lowered you are. They also give less bushing deflection with the pillowball, which in turn creates less toe change in the corner giving a smoother feel to the car.
SPL Rear Subframe Spacers
Subframe spacers are the equivalent to the whiteline "align and lock" kit, only better. Ours are made from aluminum... which is a much better material than whiteline's polyurethane. Ours are slotted to allow easy and quick installation as well.
Nismo Power Brace
The Nismo power brace reinforces the area where our tension rods mount. Giving you a smoother feel in steering and according to several people there is an increase in steering response, and a reduction of understeer.
Call us: 1-866-SPL-PART
