ooops! should've asked earlier. I'm running MS2 extra.
i'm not really familiar with ms1 extra. I'll look over the megamanual and see if i can find anything to help you though.
Alright here's what some searching found.
DIYAUTOTUNE wrote:Using the MS-I PCBv3 with MSnS-E firmware
* This is assuming you are starting with an ECU built up like I build my assembled MS130-C MegaSquirt-I PCB3.0 units. If you are building your unit up from a kit you can implement these changes during assembly. * Flash ECU with MSnS-E version 029v or later. (How? Click Here.) (Or Here) * Jumper IGBTOUT to IGN to send to IGBT ignition coil driver signal out of pin 36 on the DB37. * Cut out C12 and C30. (Only needed when triggering from the - terminal of the coil, which you are not) * Remove D1 and jumper it, or just install a jumper wire across it's leads. (Only needed when triggering from the - terminal of the coil, which you are not) * Cut out R57 if fitted (this won't be there on my units though). * Get a 330 ohm 1/4w resistor and cut the leads down to about 1/2" at each end. Maybe a bit less. * Tin each end of the resistor with a bit of solder. * Cut a 5" piece of hookup wire (22ga is fine) and strip just a 1/8" or so. Tin the stripped wire with solder. * Melt the tinned wire tip to one end of the tinned 330 ohm resistor tip and let it cool.
* Heatshrink wrap this wire/resistor assembly.
* Use this wire/resistor combo to jumper the 'top' (top as in when you facing the silkscreen side of the PCB, with the text so that you can read it normally) lead of R26 to IGBTIN on the opposite side of the PCB.
So did you do this already? because that would definitely screw up trying to get a distributor reading.
Other thing i can find is this picture of the ignition settings. I would think you need to turn distributor on, turn all the other top code settings off. then set whatever pin you've got wired for the spark output as spark output A.
Just make sure prior to setting this that you set spark output to inverted. i had it set wrong and accidentally burnt out a blaster coil last year.
