Remember those people are commenting on their used transmissions with who knows what kind of maintenance?jonseyq45 wrote:This firms up the shifts, no hang time. It also allows wot shifts with no slippage. After reading what people had said about the "slush box" and its shifting characteristics.
You want SOFTER shifts?!?!!?!?!Paul Wall wrote:Do you have anything for softer shifts?
I don't think someone would be so eager to get one of these to you that they would run durability tests-gotta gamble.Paul Wall wrote:if he can prove that this will not affect transmission life, and down and up shifts will be quicker then i am willing to test one.
Jonsey,jonseyq45 wrote: ...
I figured that there could be a market for this, but after thinking about all the help I have received from this group, I plan on giving the information and plans away for free. If you guys are interested in something like this, just let me know and I will follow up with the finished product.
Jonsey…..
Good for you, Drake. Did you use the the Ford one? Does it filter to the same level as the OEM one? Think it is only a few microns, but can't recall. I wonder if the pressure relief valve is at the same setting? Was the one in the old filter tripped? Did you look at it internally?Drake57 wrote:I did add a B&M cooler and replaced the OEM transmission oil line filter with an external spin on filter so you may add that to your count Brian. If my automatic fails, I'm thinking 6 speed manual.
When I drive my dad's Maxima with the excellent 5 speed auto, then get back in the Q, I get very strong urges to rip the gearshift lever loose and beat the transmission to death with it. I can't believe it took Nissan that long to get it right.Jesda wrote:Its a fairly terrible transmission by modern standards. I'm glad folks are rigging up solutions to reduce wear and improve performance.
Actually, it is a lot more heavy duty than it's succesor the RE05. Also, it outlives the BMW autos substantially if maintained, barely if not.Jesda wrote:Its a fairly terrible transmission by modern standards. I'm glad folks are rigging up solutions to reduce wear and improve performance.
I've tested a JWT TCU on my turbo and was unimpressed. I noticed no significant change good or bad. It felt exactly like my OEM TCU. Only benefit I could see from the one I tried would be if you were converting a 90-93 to first gear start. Had I forked over the large wad of cash JWT wants for it I would have been extremely upset.maxnix wrote:...I think changing the TCU program would be a more effective approach on one in new condition. Like JWT did.
