Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Mar 10, 2009 11:52 am
The problem is each transmission will be different depending on exact clutch wear, pump pressure vs rpm, ATF brand viscosity vs temperature, and internal leak arounds.
Heck the voltage to the solenoid will be different based on alternator regulator.
If you are trimming to 1.0 ohms expect these variables............you could use a computer to trim just like TCU does with fluid sensor.
Look at solenoid current graph vs time with different ohmatic values as the main purpose of the resistor in parallel with solenoid is TO PROTECT THE TRANSISTOR IN TCU from back emf after the shift when the power is removed from solenoid...........................too high ohms and pow goes TCU!
