My CA18DET 500 Project
blanc0
I got my oil pump today (second design), its gasket, the timing sprocket, the rear main seal (Cometic) and some dowels.
blanc0
Also got the rear retainer :)
blanc0
Got some more misc items.. it doesn't seem much compared to, i.e. a set of pistons, but I'm on a very tight budget in this period and I am forced to spend money elsewhere.
Anyway, what I got is a K & N oil filter, a Herth & Buss Jakoparts 82-degree thermostat + gasket, Contitech PS and ALT belts, the oil jet check valve for the block, the crank pulley bolt + washer and the oil strainer + it's mounting bolt lol.
That's about it for now.
float_6969
Where did you get the oil check valve for the block?!?! I STILL have two of them on order from 3 months ago. I ended finding out one from a VG30DE(TT) works.
blanc0
Ordered one from a shop from here and they themselves ordered it from Japan. Took a month to get here.
