91QAZ wrote:Wes, I bought the car with the 15" BBS wheels and mismatched tires (Visa in front, Dayton in back(?)), but plan on installing 17" wheels from a '00 Maxima SE and Michelins.
I need to do more research on runout gauges and vibration amplitude analyzers. I've never used either before, but sounds like I may be learning in the future (if the are cost effective, that is).
I read PD - 5, 6, and 7, and it SOUNDS like I would only need to check runout on the companion flange if it is removed, otherwise I should be able to use the existing B and C marks (?). I don't see where it describes coming up with mark A on the first propeller tube, maybe the first tube comes pre-marked with "A" (?).
What I don't know at this point is what is included in a new driveshaft assembly. It seems that it should include both tubes (already connected and phased at the companion flange) - everything from transmission to differential, but maybe I'm wrong. IF the assembly includes both tubes, I guess I still may need to deal with phasing between the second tube and the final drive (differential). Maybe that's what Dennis is referring to. If I'm wrong then maybe the new driveshaft only includes the first tube, and I'd need to phase the first tube to the companion flange.
I'll call Joe tomorrow and learn more about what is actually included in the driveshaft assembly. The education continues...
I think the tires are contributing.. Ive never heard of both of those, but they kinda sound like crappy tires (no offense)
I dont know what that analyser thingie is but I have a feeling it would be easier for you to take the car to dennis who knows how to use all this crap then for you to try and figure it out... The data is only as good as the person who can interprit it!!!
Youll be safe using just the dial indicator..... I want to buy one for myself too sometime...
The driveshaft includes both tubes..... I checked it in the FSM.....
The A mark is factory.....
