my built ka is done!
j-z
Car: 95 240sx
welp shes finally done and ready to be dropped in. just waiting to get my flywheel back from being lightened and balanced, and then i can mate the motor and transmission. everything was done by me and only me. the only help i got was from my pops to actually help me maneuver the motor and transmission out of the car once attatched to the hoist, and hell be doing the same when i put it back in. ive been working on it for about a week and a half straight. not full days though as its way too fuking hot down here. even in the garage its still hot as hell. i would do mostly all of the work starting at 6pm and work till i thought i had enough. i know the pics are ****ty, but i was in a hurry so this is what you get.
empty 240 bay. nothing weve seen before.
thanks edub for the very clean snail
nismo rail adapter along with an egr block off i whipped up earlier in like 10 mins. and that braided line is attatched to my oil psi sender just waiting to find a good spot in the bay.
24x12x3 waiting for some air to be forced through it
3m window weld filled mounts
MODS:crower rodsarias 8.8:1 pistonsarp headstudscometic headgasketclevite bearingss13 240/248 camsnew oem oil pump and water pumpjgs log manijgs 4 bolt downpipejgs wastegate dumptubejgs oil feed/return with restrictorgarrett 4 bolt t3/t4e .63a/r 50trimtial 38mm wastegate24x12x3 bar and plate front mountpolished aluminum 2.5'' charge pipinghks racing bovz32 mafdenso 550 side feedswalbro fuel pumpmegan racing fuel pressure regulatorngk bkr7e-11 plugsspec 6 puck sprung clutchlightened flywheelk&n 9'' coneapexi safcapexi itcdefi boost, oil psi, egt gaugeszinda motor and transmission mountscustom dual electric fan conversionpolished valve coveraccell ignition wiresmegan racing 3'' SS downpipe megan racing 3'' stainless n1megan racing 3'' SS test pipe
damn im ashamed on how shltty these pics came out. the motor is really really clean. i put a nice coat of gloss black on the block which made a significant difference. this was my first motor build ever, and it was quite fun. id rather do everything myself that way i know its done right, and plus you save money. right now im just gonna break her in for 1k miles or so. put some synthetic in her and boost 1 bar tuned on the afc and itc. that should put me at the 300 wheel mark or higher. when i want more, which i know i will, im gonna upgrade to 740s and an enthalpy ecu.
240sxfan6882
Car: 1995 240sx
Wewt! Awsome! looks great! Mine will be in next week and then ill take it from there. Gl with everything! I can't wait for it to get cranked for the 1st time!
jkerr240
Car: 93 240 sx
hey i have a quick question how much did u spend in all on parts and everying thing and did u have the head and everything machined and all the goodies
j-z
Car: 95 240sx
uhmmm thats a question i dont want to add up. i did every single thing to this motor myself. i checked all the clearances, honed the cylinders, and lapped the valves. the good ol' ka is stout! forgot to add that i have a full felpro gasket set as well. so i replaced every seal in this bltch including valve stem seals. all the actual motor parts i got in one package from AMS which is one of our sponsors. that alone was 1500 or so. the jgs build up kit was 700 minus turbo and wastegate as i sourced those out elsewhere. thanks again edub for the turbo! and i stop here on adding shlt up.
240SicknessX
Car: 96 240 SE
Very good, maybe go over all the new hardware that was used on the installation and retorque them. The heat stretches the bolts so things that used to be really tight arent as much after a few heat cycles.
i hope the you will be able to break in the car with the safc settings i sent you, be careful and change that oil like mad.
j-z
Car: 95 240sx
thanks homie for those settings! i went by the FSM (the fuking BIBLE!) on the head studs. torqued them fully in sequence, and then totally loosen, then do the sequence again with a bit more ft. lbs. i think ill be good on that. thanks again on the safc lecturing you preacher!
hannibal
Car: Red Line to Glenmont
Props on doing this all yourself! Can wait to see some vids of it running. Hint, hint, haha...
Kinda off topic: I've been under the impression that it takes a lot of expensive and specialized tools to assemble a motor. Is this true??
j-z
Car: 95 240sx
thanks. doesnt really take alot of tools to do a motor. but i did have to go out and by tools that i didnt have. i had to buy a valve spring compressor ($30), valve lapping tool w/compound ($5), cylinder honing device ($30), telescoping bore gauge ($30), plastigauge ($1), 12 pt deep 10mm for the oil squirters ($3), 12pt deep 12 mm for the arp head studs ($4), piston ring compressor ($10), and i think thats about. it was all def worth it though as i know every single nut and bolt on that motor now and how it was done.
WI_S14_Goldie
Car: 1995 Nissan 240sx SE, 91 240 fastback LE, 1997 kouki S14, DD = 93 Nissan Maxima
Awesome JOB man! U deserve alot of credit, that KA's gonna be a beast!! how much do u think you'll be boosting? i would imagine 7+psi? anyways great job!
240sxHitman
Car: Boosted '91 240sx
great build!cant wait to see it in action (2nd hint hint). i wanna get the same kit for my s13. i also would like to do all my own work besides the honing, i dont wanna screw the cylinder walls up lol
jpadilla12
Car: 240sx
Wow, car lookin good. Can't wait to see it on the road. Maybe we meet up one day, when I finish my project ka.
steve s14
nice job!!it's good to see all of these ka-t's coming together. i give you a big for doing all of it yourself on your first motor build!take some more pictures when you get a chance, the polished valve cover looks good.
j-z
Car: 95 240sx
thanks for the props fellas. i have a 4psi spring and a 14 psi spring. the 4psi spring is staying in there until i get the motor broke in. i wont be boosting while breaking her in, but the 4psi spring is just an extra precaution incase. once i hit the 1k mile mark, ill be filling her up with amsoil, changing out the 4psi spring to 14 psi, and then driving straight to titan motorsports to have it tuned on the afc and itc. the honing isnt hard at all. as long as you have a drill and some wd40, and good shoulder muscles its cake. just keep the drill at a nice steady lowest speed possible, while moving up and down the cylinder evenly without staying in one spot. the valve cover was also done by me. took a good 6 hours, but it was the first aluminum piece ive ever polished. and yes, when i get her in the car ill def do a nice shoot for all of yall in some sun light so you can actually see how nice it is.
and JGS, awesome work! lance, if youre reading this, i really appreciate the quick send out on the custom 4 bolt downpipe. i highly recommend jgs to anyone. their mani, oil kit, dp are all great! im very glad i went with the jgs kit as the only one single bit of welding i did was the return bung.
240sxHitman
quick question, with having a 4psi spring how does that cause you not to boost? just curious on how some of these turbo parts work for future references
j-z
Car: 95 240sx
i could still boost to 4psi if i wanted, but im only leaving the 4psi spring in there just in case i did happen to boost while breaking her in i wouldnt go above that mark. the wastegate stays shut until it recieves the boost signal from a vacuum line anywhere that sees boost. once it hits that mark, the valve in the wg opens up and dumps out exhaust gas regulating the boost produced by the turbo. you can still drive your car without boosting at all. but theres some instances like getting on the freeway, going up a steep hill, or getting the urge that will lots of times cause boosting.
Jookmasta
looks good man. i wouldnt want to add up the cost either. lol. track times/dyno ratings needed as soon as she is broken in..................
partymonster 975
Car: 03 Maxima SE, 94 Corolla
thats really awesome
Redline240
Car: 95 240sx
What happened to the ITB's? Why not run them under boost?
j-z
Car: 95 240sx
sold them for 700 to fund this project. boost>itbs but dont worry, some guy in cali is running them on his kat 510. infact its the one shown in the nico/stillen meet on our homepage.
WDRacing
Lookin Good, always nice to see another KAT.
WD
Florida240sx
When you thign you'll be up in running? My engine get's finished this week. Just turboed my friends 240 over the weekend floyds13. He is at the dyno as I type this. All need to go out to sr50 or bithlo or just somewhere to hang out. 386-747-9982 Justin
j-z
Car: 95 240sx
welp, i finally got my flywheel back today from being balanced. i put that on along with with my spec 6 puck, and matted the transmission to the motor. shes all good to be dropped in tomorrow in the AM. everything will be done up and running this weekend for sure. im gonna have to get back to you florida on meeting up. i want to drive her on around a lil bit. but def in the future after shes broke in well have to meet up.
steve s14
pics, pics please! what brand clutch did you go with and is it the stock flywheel?i need a clutch too so i'm curious.keep up the good work!
j-z
Car: 95 240sx
i went with the spec stage 3 6 puck sprung clutch. and damn is that pressure plate gonna clamp like a mofo! first time i actually had to put all the bolts in for the pressure plate to get it flush mounted with the flywheel. dont worry, i didnt fuk anything up, its the way its designed for max clamping force. this is the one enjuku recommended for 400 ft lbs. as for the flywheel, i had my stock one lightened to 14 lbs 8 oz. they took over 5lbs off and damn it looks really good. ill def be posting pics up after shes up and running. sometime next week.
j-z
Car: 95 240sx
motors in!
240sxHitman
pi
j-z wrote:motors in!
pics pics pics pics!!
rn240sx
Car: 12 Frontier V6 (supercharged)
98 240sx ka-t (fully built)
09 Ninja 650R
06 Suzuki S40
15 Hyundai Santa-Fe 2.0T
j-z wrote: this is the one enjuku recommended for 400 ft lbs. as for the flywheel
WTF..?? I called enjuku and they told me they had NO clutch for the ka that would hold 400 ft lbs..!! And to make it worse, they asked me twice how much i was putting down and they didnt believe it was a ka...
Jeez... im so pissed now..!!
j-z
Car: 95 240sx
hmmm... i always deal with teddy up there and told him what i will be putting down. the one i have is actually rated to 385 ft lbs, but he said i would be good with this one. after looking at the pressure plate, im assured i wont have to change it out for a while. you can always get the one i have and step your flywheel like ivan was talking about. that would def without a doubt hold the power.
j-z
Car: 95 240sx
MAJOR progress from working on it all day today. got the complete hot pipe/bov side done. started the cold piping/maf side so that wont take long to do tomorrow. ive just been hung up on the second o2 bung in the test pipe. i have a megan racing straight 3'' SS test pipe. when i bought it, it already had a bung in it, so i thought it would be a 2 min job to install the o2. WRONG! my fuking luck, it looks like its for an egt probe WTF?? like thats how big the ID of the bung is, so i couldnt get my o2 in the bish. damn, so i started to drill the hole out bigger one night, which took me all night. then i said fuk it and went to home depot the next day (which was yesterday) to get a real good high dollar bit. i did that and found the perfect size. $10 for one bit. started doing that for 20 mins with no fuking success what so ever. man i was i pissed! so i figured id just get an o2 bung and weld one in up further on the test pipe, and put the plug back in the shlt bung for who knows what. well today i went up to mazworkz for some silicone couplings ($120 worth) and figured theyd most likely have an o2 bung there. when i got there i saw enjukus new coupe for the first time in person even though i go there quite often (to enjuku), and i also got to check out mazworkz 9.2 sec sr powered 240. what a beast! but anyways they had every coupling i needed and the o2 bung so that made me happy. first thing i did when i came home today was drill a hole for the bung (mind you im doing all of this under the car on jackstands cause i was too lazy to take the pipe off) and come to find out the bung i got was way too big. damn was i really pissed then. so then i said fuk it cause the ****ty bung already on the pipe was the size i needed so i cut that fuker off and welded it in the new hole i just drilled. came out perfect. then i started fiddling with the ****ty bung hole (lol no pun what so ever intended, the one on the pipe!) trying to tap it and plug it with a bolt. kept drilling on it with diff bits to get the tap started and nothing wanted to happen FUK. i then again said fuk it again and shouldve done this from the start, so i brought the welder back out again and welded that bish shut. took me 23 secs and everything went good from there. i was just so pissed from being stuck on that damn pipe for the past 2 days. got the driveshaft in, sone other small things and started on the piping. so if i put in a full day tomorrow she may get started. but im not gonna rush it, so most likely monday itll be game day. i still gotta custom mount 3 gauges and wire them up. thats the only big thing left though. shes looking clean!
skylinekin
Car: 1990 Nissan 240SX Hatchback
I love your car, those wheels are bad ***
