Project Deviance
4 years ago I tossed the #3 rod right through the side of my block. It sat for so long the tires went flat and rabbits ate a big chunk of the wiring under the hood. I towed it around the country because we moved 2 more times after it popped. The amount of work it was going to require to get it running again totally destroyed any motivation I might have had. A good friend of mine and Nico staff member recently had some nasty s***e happen in his life. We had all kinds of really good advice to give him. But Greg, AZHitman, said something that really made me think about where my life was going. He said sometimes you just have to unload all the negative equity in your life and start over. Or something close to that...anyway...I had so many projects on my plate that I was simply overwhelmed. So I traded my K5 Blazer for a huge Thomas The Train set. My son Dylan (2) loves it, instant win for me. I junked my spare S14 and I chose to get the f*** up and get the damn car running again.
Last night she started and drove under her own power for the first time in 4 long years. I lapped the block a few times, no electric fan yet, and she didn't even stall or throw a code. Which is F'N awsome considering I jut rewired every sensor under the hood. It was an excellent first drive.
It took 3 weeks of almost daily sessions to get her rewired and running. I had to stop often since my main job is taking care of Dylan. That and I hate wiring...HATE. So I would get so pissed off that I would have to walk away to avoid adding fist prints to the hood/fenders I have some anger issues
I digress...I ended up having change the fuel pump and the damn sender because they both went bad. Then I had no ground from the ecu to the fuel pump relay. I'm not a fan of hot wiring the fuel pump, I like to know it will shut off if I wreck Turns out my dumbass didn't connect the crank alignment plug
Once I had power everywhere I couldn't get her to start. So I played the dizzy game for 2 days because I kept going off a tooth, then I installed the plugs in the wrong damn firing order without realizing it...which made me redue the timing more then once FOR NO REASON It just goes to show that no matter how many times you've done something or how much you THINK you know...we all make really stupid mistakes
So she's in need of a serious cleaning and I have a ton of little things to finish up. But the project is underway. I'll try to add a new post every couple of days with actual progress.
Here's a NEW teaser pic...
The end goal is to have the supercharger mounted semi-close to where you see it in the above pic. No...I'm not joking. I'm also going to run a staged propane injection system that I've been working on and talking about for at least 5 years. I'd like to take this time to Thank Chris, MinisterofDOOM one of our admins, for donating the supercharger for the price of shipping. No way I could be doing this otherwise. Again, my plans have changed on pg 2 and I'll now be using a turbo instead of the charger.
This project is going to be an expression of my personality to the best of my ability. Lots of boost and Propane Injection screams obnoxious and out of control. Which is how I have always approached cars. Enter Project Deviance.
WD
