^ TruthAZhitman wrote:Hmmmm...
I don't want to disappoint you, but if he is TRULY laying down 726 hp (I call BS if it's a street car), you'll never touch him without THOUSANDS of dollars in work to an SR.
He's basically running an NDRA car and you're driving a stock economy car that just happens to have a small turbo.
Take some time, read a LOT of posts here about high-hp SR's, and please, please, please let's spell "boy" correctly if you want to be taken seriously.
Welcome aboard!
Very good piece of advice.AZhitman wrote:...and please, please, please let's spell "boy" correctly if you want to be taken seriously.
What size turbo is he running to make 726hp at only 18psi? I find that hard to believe, anything big enough to do that wouldn't spool on a b16.R-Yahne_240 wrote: hummm i have a s13 with a sr20det black top and my boi just tuned his b16 civic at 18 psi completely built and hes running 726 hp on race gas
S13FREEAAK wrote:What size turbo is he running to make 726hp at only 18psi? I find that hard to believe, anything big enough to do that wouldn't spool on a b16.
+654651681 for Greg!AZhitman wrote:Hmmmm...
Welcome aboard!
i've seen hondas put down some pretty poor #'s as well but there are still plenty of hondas that do put down some really nice #'s. i have friends making well over 300 on boost in the low teens. but the is no way that that guy made 700+ on 18psi.S13Coupe wrote:I agree. I've seen hondas running like 10 pounds and still putting down numbers below 200. That guys probly only somewhere in the 250-300 whp range.
are yall only into nissan motors or are yall really into cars and a true fan of tuningSeishuku wrote:Yeah, most likely. Unless the engine is running high compression (10:1+), then maybe 500HP... But still doensn't sound likely to me.
check the compression on a b16 a 1Seishuku wrote:Yeah, most likely. Unless the engine is running high compression (10:1+), then maybe 500HP... But still doensn't sound likely to me.
