[PLEASE HELP] my 97 Q45 won't start.. from a car newb..
dr.styller
Hi all,
I have been desparately looking for an answer to my problem but I have no idea what to look for mainly because I know NOTHING about cars.. (yeah maybe just tiny bit since I am still a guy.)
Anyway, I have 97 Q45t with 170,000 miles on it. One day I started the car and it didn't start (it worked just fine the day before).
To be more precise, the car "tries" to start as it makes that starting noise but the engine doesn't get started.. It seems to me that battery is working fine but something that delivers the power from the battery to engine is not working.. (that was my logic)
I really don't wanna spend hundreds of dollars with towing and repair costs since I will be using the car only for next 6 month or so...
So could anyone help me please?
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
How many miles are you looking to get out of your Q in the next six months?
dr.styller
you asking me that doesn't really help me much does it
mtzgr777
Car: 1996 Infiniti Q45 143k Silver/Black
I'd consider myself a car newb also, but I do have an idea. I had similar problems with my '96 Q45 except mine would still start, it just took took a pretty long time. Yesterday I changed the fuel filter and it starts up and drives amazingly. It costs about $13 and it's well worth it. Mine was so clogged that when I tried blowing through it, I felt NOTHING on the other side. I've read that this should be replaced every 3,000 miles I believe, so if you're unsure of when it was last done I'd replace it. Also, cleaning the Throttle Body made a world of a difference for me...just take a $3 can of Carb and choke cleaner and spray away inside the TB until it comes out clear, as shown: http://q45.org/tbclean.html
Hope that helps.
dr.styller
mtzgr777 wrote:I'd consider myself a car newb also, but I do have an idea. I had similar problems with my '96 Q45 except mine would still start, it just took took a pretty long time. Yesterday I changed the fuel filter and it starts up and drives amazingly. It costs about $13 and it's well worth it. Mine was so clogged that when I tried blowing through it, I felt NOTHING on the other side. I've read that this should be replaced every 3,000 miles I believe, so if you're unsure of when it was last done I'd replace it. Also, cleaning the Throttle Body made a world of a difference for me...just take a $3 can of Carb and choke cleaner and spray away inside the TB until it comes out clear, as shown: http://q45.org/tbclean.html
Hope that helps.
thanks for the reply.Do you by any chance know where the fuel filter located on my car?Do you need any tools to do that? All I have is philips screw drive..
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Hope that helps.
You have come a long way.
Fuel filter location: zerothread?id=111986
