My 560ZX ( Titan VK56DE powered 280ZX S130 ) Build Thread
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
XJared
Car: 06 Titan, 83 Z, 10 Z
Updates are a little slower these days. Should have another in a month. Don't know how to turn on my messages, didn't even know this site had them. I'll look around.
Ba11erz
Car: 90' 300ZXtt
Stage IX
502RWHP 93 pump (May 2011 Tune by SZ)
VH45DE Swap in progress
I'm going to use my EMS 30-6620 on my V8 swap.
I was under the impression that [all] AEM EMS Series 2s can support up to (8) eight coils.
I flipped through the installation guide but don't see (2) additional 0-5v/ output spares for use.
Is wasted spark the only way to use a 30-6620 that's PnP for a V6 VG/RB on a V8 VH motor?
Any help on this will be great!
XJared
Ba11erz wrote:I'm going to use my EMS 30-6620 on my V8 swap.
I'm using a series 1 Honda box. It only has 5 coil outputs so I'm running waste spark.
Your 6620 has 6 enabled outputs, but from what I understand the series 2 has 8 outputs. In Tuner, go to Display>Coils to enable coils 7 & 8.
Ba11erz
Car: 90' 300ZXtt
Stage IX
XJared wrote: In Tuner, go to Display>Coils to enable coils 7 & 8.
Wow! That was easy and much thanks @XJared for a speedy response.
Whelp, I cracked open AEMTuner v2.98 and pulled up the coil display as you suggested and noticed [Coil #7 & Coil #8] were not active.
Checked those boxes. :chuckle:
So, now that they're enabled, which wire positions from the EMS side have become active?
As I look through the install guide the only "spare" 0-5v analog/digital pins are characterized as input signals. :confused:
Here's a snapshot of pins 104 & 37 I'm referring to:
Additionally, the guide doesn't clearly illustrate the spare coil pin #'s unless it requires identifying two free output spares and configuring them for the output firing group order and phasing.
Any thoughts?
Ideally I'd like to get the EMS setup properly so later I can add the twin fire to increase the spark and dwell for greater efficiency.
XJared
Making it go straight.
XJared
Two steps forward and one step back. I need a degree more negative camber in the RF.
XJared
First real drive ever after getting some bugs worked out.
XJared
Gauges work!
This is so darn amazing... WOW.
Ba11erz
Car: 90' 300ZXtt
Stage IX
Nice! great work all around
XJared
Thanks guys. Couple videos coming soon.
XJared
At idle, it sounds like any Titan with exhaust.
https://youtu.be/Tw9sEAsM8Ow
XJared
Some light throttle acceleration. Still no hood. Redneck style FTW.
https://youtu.be/pHz-sgRJUXI
cincysilvias14
Car: 2008 350z touring
2004 350z enthusiast
you sir are my hero. this is amazing!
XJared
cincysilvias14 wrote:you sir are my hero. this is amazing!
Thank you.
XJared
Hood in primer:
XJared
Hood parts here:
Return to “VH45DE / VK45DE / VK56DE Forum”
