SketchyRollin564 wrote:
Im so confused. How many different 2JZ's are there? Whats the difference between them?
An RB26 is an RB26. Sure there was a 6speed on the 34, and the 5 on the 32 and 33 but its all the same.
Mabey someobody could explain?
Here are the differences between the 2JZGE and 2JZGTE
GTE has oil squirtersGTE has thicker/better rodsGTE has lower compression pistonsGTE has a different port position head, as well as flow designGTE has a different intake manifoldGTE has a water coiled oil filter housingGTE has the p/s pump mounted in a different positionGTE has 2 cam sensorsGTE has no vvti (american spec)GTE is not drive by wireGTE uses different motor mounts (interchangable dependent on year)GTE uses a different lower girdle/oil pan, oil pump sump and oil level sending unitGTE uses a different oil pressure sending unitGTE uses a fuel return system
