my 240sx ford 302 engine changes (lots of pics)
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
maik21
Car: 90 Nissan 240SX Coupe 5.0
im with the "poor team" too ... good to know ... i upload a pic of the engine plastic supports... maybe it will help u a lot.
maik21
maik21 wrote:im with the "poor team" too ... good to know ... i upload a pic of the engine mounts .....maybe it will help u a lot.
maik21
thats the way i have it installed in my car... i dont have a real engine in my room so the supra its very well explain the idea.
nookie2692000
Car: 2 91 coupe`s. one going 302 fully gutted street beast
i should have my mounts made by next weekend at the latest. all depends on when my buddy can get to it for me.
nookie2692000
got the stock motor and trans out today. removing all the wiring and other things i dont need from the bay and going to paint it. i hope my buddy can come by sometime this week so we can get some mounts made. ill take pics and post later today!
maik21
that sounds great !!! i hope u will have good luck !!!
nookie2692000
doing the top end gaskets today. got to talk to my boss too. am supposed to be getting some gt40 heads from him for my motor. maik.. what is your water pump from and did you use the timing cover that came on your motor? what year is your motor and whats it out of?
nookie2692000
got the entire top end off now. going to wait to put it back together. it will be much easier making the mounts with the heads and intake cuz you can see where the mounts go better. and im waiting for my gt40 heads.... meanwhile im going to get the top end all nice and cleaned. i will post some pics up later today.
maik21
nookie2692000 wrote:doing the top end gaskets today. got to talk to my boss too. am supposed to be getting some gt40 heads from him for my motor. maik.. what is your water pump from and did you use the timing cover that came on your motor? what year is your motor and whats it out of?
i think engine came from a ford cougar 87 but maybe it was swaped too. water pump came with engine and its aluminum and custom too. timing cover came with the old style for mechanical fuel pump but i swaped to a newer one last december bacause i dont run mechanical fuel pump.
some engines 5.0 HO came with a small water pump and maybe u will not need any custom part.
nookie2692000
sandal is a size 10. used for reference. you can see how much i will need to dent or cut from the firewall. a damn does that v8 look good in there! this is it for now guys.
maik21
it looks very very good !!!! waiting for more pics.
nookie2692000
i removed alot more stuff. theres alot of wiring that is not needed. i also removed the blower motor, heater core and all the crap from underneath the dash. removed my cruise control crap. going to try moving the fuse box off to the side so its away from the motor when its done. will get more pics later today. maik do you have a pic of your engine bay with your motor in it? like the whole engine bay? did you dent your trans tunnel or cut it out?
maik21
u can see alot of engine bay in de video in youtube... and for the trans tunnel it isnt dent o cut. its stock !!! if u want a fit , engine must be upper and transmission a little down but it is good to dent in the trans tunnel for better fitment.
nookie2692000
so what year and vehicle did you look up for when you got that water pump? and what are those engine mounts from? also. is your oil pan the frontt and rear sump? ill take a pic of my pan. my pan has a little sump up front and a big one in back. thats why i asked. that may also be why my motor will sit so far back compared to yours. you should try to get a new pic of your engine mounts with the motor bolted in. i think that would help alot of people as well. i think more people would buy mounts instead of getting custom ones fabbed.
nookie2692000
seems that you have alot more space in front and behind your motor...
nookie2692000
here is the back of the oil panheres the frontmaybe i can flip it around or cut some of thee bigger sump back and weld it.
maik21
it looks good but maybe u will have problems with sway bar. it will hit damper when u lift car.
nookie2692000
well the pics with the oil pan, i have the motor resting on the cross member. the engine block is up against the fire wall and the rear sump is up to the rack & pinion. i have to get an older ford oil pan like you have that is only front sump. my mounts will be done on monday. once my mounts are made, im going to start putting the heads and intake back together. i will than do my wiring and figure out where im going to run my harness through the firewall. after that i will bolt up my trans and get my trans mount made. after that i will measure for my drive shaft off to another friend so he can cut and weld it. than he is going to balance it. thans its all coming back out and im removing more crap from the engine bay and painting it. monday or tuesday i will have more updates.
maik21
u can get more space in engine bay if u lower the back of engine. nose up, back down.
nookie2692000
mounts will be done in about 2 weeks. in the meantime im going to putz around with other things in my car. got to make my pod holder for my other gauges. got to do the gaskets yet on the top half of the motor. will get some more pics here soon!
maik21
its almost time
maik21
one more video to my listhttp://www.youtube.com/watch?v=DRrG3lplNuQ
jesteratc
Car: 91 Festiva DD
92 240sx Sr20det Fun
2012 Kia Soul Red Rock Edition (Wifes DD)
Hello, just wondering....If you use the double sump oil pan from the mustang 5.0 and hammer in the firewall about an inch, would there be any clearance problems wth just setting the oil pan right over the crossmember?
im refering to the pic that nookie2692000 posted showing the double sump, i would probably make a new sway bar in the front.
Thanks, Andy
p.s. keep this thread going. need more info and pics
maik21
jesteratc wrote:Hello, just wondering....If you use the double sump oil pan from the mustang 5.0 and hammer in the firewall about an inch, would there be any clearance problems wth just setting the oil pan right over the crossmember?
Thanks, Andy
no.. my oil pan if from a truck. it was modded in the back to fit crossmember. i dont know how much right engine will fit with 2 sump oil pan.
i dont hammer firewall and engine sits very well.
another thing is im running a oem sway bar with a little of mod.
the black line show how i cut the sway bar... after cut in this 2 spots i take some measurements and resolder in the new position. my original problem with this was because sway bar was hitting the carter wall then driving... i remember the clearance was about .5 centimeters... i never can put my finger between sway bar and carter. the other problem is if u have clearance between swaybar and damper. i had to much clearance between this 2, so i made the cut and paste. if u dont have too much clearance this dont work to you.
and u will have this....
look at oilpan clearance !!!
jesteratc
Car: 91 Festiva DD
By looking at the position of nookie2692000's engine in where it sits up against the firewall,and looking at the pics of the oil pan, hes using the mustang oil pan from the looks of it, or at least the same pan. it appears that there is abou an 1" or so gap from the front of the pan sum to the crossmember, so this is why i was thinking that if the firewall was punched in about an inch, the whole system would slide back, this would allow you to use the stock oil pan with no mods, and just smash in the firewall and trans tunnel.
What ya think?
maik21
you are right but even with those mods maybe engine will sit to high. if u wanna try doit and see what happend. nookie maybe doit . i hope he take some pictures for us =)
jesteratc
Car: 91 Festiva DD
hopefully he will chime in and give some advice. i found some nice universal mounts for the 302 on a side called Progressive Automotive, the mounts are $225.00 for the pair, but all you need is to cut and weld, similar to just making the whole thing youself. but a little lest involved with a better result hopefully.
In the end i would like to have a kit explaining what i did, and you could buy parts from me to make it, that would be the optimal choice, but if i start modifying the firewall and trans tunnel, most people will be scared off just by that. but if i can build one and have it run and drive for a while, hopefully it will inspire me to build a kit easier to install. But thanks for your replys, its nice to get feedback on stuff
maik21
yep.. dont worry !!! this info will helps a lot of people.
maik21
new video, sunday 29 sep 2008
16.500 1/4 mile2.319 60
http://www.youtube.com/watch?v=j0imllmGg-U
maik21
i bought another engine, this time its a ford explorer 5.0
Return to “Hybrids”
