my 240sx ford 302 engine changes (lots of pics)
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
WDRacing
Weld those spider gears in the back bro!!! You need posi badly...lol.
maik21
Car: 90 Nissan 240SX Coupe 5.0
WDRacing wrote:Weld those spider gears in the back bro!!! You need posi badly...lol.
on the rear bumper? i dont know what are spider gears lol =)
sctrep
Car: 89 nissan 500sx 302 block bored 40, flat tops ported E7s, big mutha thumpr cam torker 289 intake, Holley 600 4bbl carb,
Street fire cdi ignition. gear drive
2 row allum. radiator. Z-Gate shifter
in the differential. that way both wheels pull
maik21
im using a welded diff =)
maik21
my msd 6al at home !!!
i will make the 2 step diy and try it. i need a rev limiter for engine .
maik21
tbi holley from a dodge 360 truck. its rated at 670cfm .
maik21
MEGASQUIRT II V3 ASSEMBLY. START---->
maik21
maik21
a little more update on megasquirt build.
maik21
UPDATE .... MS II v3 done.... on the next days i will try to do carb to efi and test.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Nice. MegaSquirt is where its at.
maik21
new et time .. maybe because msd ignition + launch control and better track.
ticket only give these data.KPH2 and 1320 ......
so here i go...+++++++++ MPH2 ++++13201st run--------97.25------- 14.582nd run-------97.11------- 14.273rd run -------95.92------- 13.914th run -------96.18------- 13.565th run -------95.89------- 14.00
so in the last run car spins a lot and loss traction so i dont need to run again! and then a strange sound came from distributor but engine its okay.
in the last 3 runs i set launch control to 3000rpms.
i need to switch to another cam to raise engine revs a little more.
i
Modified by maik21 at 9:35 AM 4/26/2009
maik21
Modified by maik21 at 2:19 AM 4/29/2009
arabdrifter
Car: 89 Nissan S13 coupe
wow maik21 very nice build for sooo cheap. how much did u spend altogether? im starting my 5.0 swap soon within 2-3weeks(motor im using is gonna be from an F-body stang) once i have my second car in for dd-ing, then ill be hacking away for sure. any other tips u can give me? i started a new thread so that once my build strats to come alive ill be updating it everyday. thanks
maik21
running stimulator
so megasquirt its fine and ready to be wired on car.
travisdx
Car: 1992 s13
how hard was i to build the megasqurit
maik21
hard if u are noob...
maik21
cam swap.
cam is in there but because some unknown lifters i stop the assembly.
wrxratd
Car: 1990 240sx hatch, 2002 WRX
Very cool. Huge props to this ultra DIY swap. Keep up the great work man. You're an inspiration to all!
maik21
efi megasquirt halted right now, i dont have enought money right now to buy fuel components so i will survive without efi some more months.
right now , mustang cam swap its done. its more loud and i can rev past 6000 without problems.
for stock s13 cluster, gas, temp and TACHOMETER its working very well with help of this myself made thing
it convert any signal from a v8 pulse to an L4 pulse compatible with our clusters.
no drag times right now because track it idles.
ruca its intalled too for better 60 ft.
i need to go back to 25.1" on the back tires because i im running right now 25.7"
maik21
bad weather !!!
water was 3/4 of wheel after 15 minutes when picture was taken. then us try move my car pushing it to a safe place. interior was full of water so i need to remove seats and carpet and clean it.
engine and electronics are fine.
WDRacing
Holy crap dude...
maik21
- aem wideband installed. (one more thing to complete efi setup.)
- new carb 750 holley with more gas injection.
- rear camber and toe fine. (better traction)
im waiting($$) for testing on drag soon.
car feels more powerful on high revs so maybe better E.T or more final speed.
maik21
i went to drag test my car yesterday. goood news:
- best et was 13.08 with same tire setup.- car spin a lot if i push it hard on 1st and 2nd gear even if i went from roll.
tickets will be tomorrow because damaged picture camera.
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Updates? Ive thought about doing the 302 in my S13 now. Seems to fit really good and parts are cheap for it. Im more looking at a EFI 5.0 and do a turbo build.
maik21
car is on slick tires right now. so im waiting for a drag day !! tires are 26"x10.5" on oem 15" wheels
maik21
maik21
not the best looking car ... i dont swap to efi yet because i get some slicks and i want to test on the track before doing efi !!
maik21
my engine motor sounds diferent from others 5.0 . cam and carb makes engine sounds diferent too
http://www.youtube.com/watch?v=9OhYtr0FKGg
next december 20 will be open drag track so maybe i will go. i hope 12.9 in 1/4 mile with slicks without any damage in drivetrain.
Slidin sideways
Car: 1990 Nissan 240sx
Having a bit of a problem with my swap. Trying to find the engine to mount plate for the explorer mount but I'm having no luck. Anyone know where to find them.
Return to “Hybrids”
