dr-rjp »
https://forums.nicoclub.com/dr-rjp-u48968.html
Fri Oct 05, 2007 8:45 am
Didn't mean to leave you hanging on the issue of "fuel delivery."
When I said, "fuel delivery," I meant all of the things that deliver fuel & air and that monitor fuel delivery and the fuel/air mix, things like fuel pump, fuel injectors, throttle plate, throttle position sensor, MAF, idle air control valve, and anything else actuated via vacuum pressure.
The crank position sensor, IMHO, is not what is giving you poor gas mileage.
Bad O2 sensors would, and they can go bad w/o throwing codes, but since they are offline when you are start a cold engine, you can rule them out.
The throttle plate might be sticking, but it would have to be virtually closed for the car not to start.
The throttle positioner, on the other hand, could be giving false signals, and causing your car to run rich, but I don't think it would prevent you from starting the car.
A bad MAF most certainly will prevent you from starting your car and running properly, but the ECU usually (but not always) throws a code.
The IACF mainly affects idle speed. A bad or clogged valve would cause your car to idle roughly, but it would not prevent it from starting.
OK, has anyone checked for vacuum leaks? They will reproduce all of the symptoms you are having.
AND, anything that cuts off the air supply getting to the throttle.
That's my 2 cents.
