iceburgslim wrote:MR2's are complete whores to work on. I've worked on many many cars and the MR2 takes any pleasure you may get out of it and shoves it up your A$$.
FinalDrive wrote:I recently put an hks hiper exhaust on my mr2. It took 45 minutes, including dropping the rear crossmember and stopping to take pictures to put on my site of the whole process.
Nils wrote:but from what I have heard from other mr2 owners is that the car is very tail happy on the road course. I dont know that for a fact though since I have never driven one.
Exactly. I'm looking for an s13 to park next to my MR2 as we speak.Nils wrote:What ever car makes you happy... makes you happy.
FinalDrive wrote:You heard correctly. An MR2 suffers from "snap oversteer" as we on the MR2 board call it. The car is an amazing handler, but if you push it past its limit, good luck.
if you don't brake or accelerate. most race cars do have a rear balance. also look at most porsches. a rear balance lets you brake later and accelerate earlier.Dori Dori wrote:Ideal is 50/50, sorry. Always has been, always will be. More weight on either end gives understeer/oversteer...neutral balance is the best. Take the 360 Modena for example. Ferrari is definately someone that knows what they are doing. Ferrari placed the radiator on the front of the car to try to reduce the weight in the rear. This brought the weight distribution to 43/57 (street car). In the race car, it's supposed to be even closer to 50/50...but race teams don't usually give out that kind of information, so one can only assume...
they are tail happy because they are ment to run larger rear tires then they are given stock and because the 91 and 92's had very short suspension set-ups. Like most race cars, larger tires help get the power to the ground in back and considering that rear tires don't actually get to turn they get a lot of weird forces on them when cornering hard.Nils wrote:It took me 20 minutes to put on the exhaust on my 240, including stopping and taking pictures
Not that ease of work would stop me from buying a "quicker" car or that the mr2 isnt a capable sports car... but from what I have heard from other mr2 owners is that the car is very tail happy on the road course. I dont know that for a fact though since I have never driven one.
Going back to the original and n o o b question - "Fast" is a very relative term, what you might think is fast might be slow to someone else..... Fast in a straight line does not mean fast in a big turn and vice versa. When asking such a question, you have to be more specific in detailing your opinion of what fast means.
In either case, if you have enough money you can make anything fast. What ever car makes you happy... makes you happy.
I dont really care what brand my car is aslong as it meets my criteria of what "fast" is in some sort of fashion.
n
toy turbo 2 wrote:this has to do with the actual suspension pieces not the wheel base.
1. I'm not going to fight w/ you about a vehicles weight distribution and which is better. The fact is that every race team and every driver has a different view on this. Some people like more rear bias, some people like 50/50, and sadly some people like front bias. But I will say this...the car world calls a 50/50 balanced car 'ideal weight distribution' for a reason.toy turbo 2 wrote:if you don't brake or accelerate. most race cars do have a rear balance. also look at most porsches. a rear balance lets you brake later and accelerate earlier.
my brother also owns a miata w/50/50 weight. when you brake late into a corner the rear end wants to come around, with the mr2 i could brake until the really hard cornering came on.
look at thew lotus elise, it puts up better handling numbers than even the ferrari and it is right at 40/60. also radiators go in front for cooling in about any car, its much easier to get the air in the front and the heated air doesn't heat up the engine bay.
