fabio240 wrote:RS12turbo would you happen to remember fittings your lines are and lengths because I too will be running a big 16g and also how much power do you think your putting out
the coolant banjo fittings for the 16g are the same size as the ones for the t25g.....I just re-used my s/s coolant lines that I had on my t25g. Length wise, I think they are 27-30 inches.
The oil feed line i used is a -4an and is 24 inches long
http://www.summitracing.com/parts/NOS-15230NOS/
The adapter fitting that I used to screw into the ca block adapter is a -4 to 12mmx1.0
http://www.summitracing.com/parts/EAR-9919BFEERL/
The turbo side oil feed fitting I used is a 12mm to -4 male banjo fitting.....I got it from the place i bought my turbo...http://store.forcedperformance...rboHW
Looks like the turbo's are still on sale too.....$499 http://store.forcedperformance...Turbo
Power, i'm shooting for 280whp......we'll seeHope this helps......
