Darius »
https://forums.nicoclub.com/darius-u5470.html
Tue Nov 21, 2006 4:55 pm
Here is an update to this thread. Man I get a kick out of reading all that stuff and how desperate I was. Newbie!
Anyways, I went to install my PFC tonight and to disable the boost controller kit option they say to turn the key to ACC and the hand controller light should turn on and disable it through the menus. My hand controller didn't light up, so I flipped the switch that normally gave my standard ECU power and it turned on. I didn't feel comfortable trying to start it with it wired that way because there is obviously a problem and the discontinued PFC isn't cheap or easy to come by.
Here's what I have at my relays:Key in the OFF positionIGN relay - 1,2 have powerECCS relay - 1,2,3 have power (shouldn't 5 have power too )
Key in the ACC positionIGN relay - 1,2 have powerECCS relay - 1,2,3 have power (shouldn't 5 have power too )
Key in the ON positionIGN relay - 1,2,3 have powerECCS relay - 1,2,3 have power (shouldn't 5 have power too )
If I flip my jumper switch and the key is in the ON position I getIGN relay - 1,3,5 (that's odd)ECCS relay - 1,3,5 (that's odd)
FYI the 5 position on the ECCS relay is the B/W wire that is the ECU power wire and plugs into the ECU at pin 49. It seems that even though I have power to the 3 spot on the relays, the relays are not closing to send power to the ECU. I changed relays out with some others that I had laying around and there was no difference in the outcome.
Modified by Darius at 8:12 AM 11/22/2006
