Here is my confusion (and I am trying to contact a Australian or UK Nissan dealer for some info)
CA18DET OEM Engine Mount Part Numbers
Source - http://www.nissan4u.com
RH Engine mount - 11210-35F11 (#9)
LH Engine mount - 11220-35F11 (#16)
KA24E OEM Engine Mount Part Numbers
Source - http://www.nissanpartszone.com
RH Engine Mount - 11210-40F00
LH Engine Mount - 11220-40F00
http://www.nissanpartszone.com/Page_Pro ... entsNo=112
^^for the above link, you do have to put it some info to look up the mount numbers to verify.
The CA18DET part numbers crossover to the KA24E part numbers
RH Engine Mount - http://www.nissanpartszone.com/parts/ni ... 35f11.html
LH Engine Mount - http://www.nissanpartszone.com/parts/ni ... 35f11.html
In my eyes, this would mean the mounts for the KA24E (atleast) are the very same as on the CA18. Like I said, I'm trying to get in touch with some dealers overseas and see what I can find out because this is really kind of racking my brain. I have gone through almost every post I could find on KA mounts not working on the CA and that the SR and KA mounts are the same. I'm starting to think that somewhere down the line, a lot of companies found you could use SR mounts on a KA and have them work to no ill effect and starting listing KA and SR mounts as one of the same. As you can see, NISMO does not actually have a KA mount listed: (http://www.nismo.co.jp/en/products/comp ... mounts.pdf).
I know this has been talked about over and over again, but the information just isn't adding up for me..(BTW google search of KA24DE shows they do have a slight "lean" to them similar to the CA18)
Comments, flaming, etc. all appreciated guys. Thanks
