By way of looks...sure they are identical in every way. Nismo mounts are solid compared to the liquid/gel filled center on the OEM mounts.artemous wrote:The mounts are identical in every way except that the nismo ones use a harder rubber and I believe have an inner reinforcment incase the rubber breaks. I am running the nismo and find them great. I also believe that the KA and SR mounts are the same for this car.
Yea you need to swap the mount of each side when installing on the KA24DE. Nismo mount L goes to the driver side and R goes to Passenger. I swapped them when i installed mine after reading several posts. I did not try to do the other way for a test fit, but some people have commented that if you don't swap them, then you will not be able to reinstall the metal bracket on the mount.realseals13 wrote:So let me get this straight... U use the sr left mount and right sr motor mount then switch them and thats how you install them on a ka24e/de? I installed the left side with the left nismo motor mount and it seemed fine. Is this true?
I was thinking the same thing.brizanden wrote:ok dead thread revival but if the ca one is 69mm part no 11210-RS520 why not just get two of those? thus the stock height will remain.
Hmm, interesting idea. There are minor differences between the left and right side mounts, though that's not prevented people from swapping them.brizanden wrote:ok dead thread revival but if the ca one is 69mm part no 11210-RS520 why not just get two of those? thus the stock height will remain.
EDIT !!!! Just noticed I actually responded to this post a while back. Dude read the posts above. The info is there.derass wrote:Silly question but does the mount marked LN go on left (driver) side?
