BoostsFed wrote:did you get your A/C running with the rb20 swap?
IvoryJ30t wrote:if someone gives me a wiring diagram of the rb your using, and your car, ill tell you how to hook the ac up.
HybridOne wrote:i run boost at 12psi all day. I think 14 is the limit of the Turbo. And i wouldn't run over 14 with the intercooler either. I WISH i had my HP numbers. I was having my car dynoed and the guy running the machine kept shutting my car down at 4000rpm because he said i was running WAY to lean and he didn't want to blow it up. I was at 13:1. Isn't normal 14.7:1 and anything above 14.7 lean. I think this guy was an idiot. Anyway...i had 175hp to the wheels at 4000rpm, and the graph was moving up and up. I wasn't even really in my powerband. annoying.
Yellow4g63 wrote:13:1 is pretty lean for turbo. Leanest I would go would be 12.5. So you made peak power at 4k rpm what size exhaust did you have and was this with the cat or no cat?
AREITU wrote:To my knowledge, nobody has AC and RB.
But I was thinking, if you lay both harnesses on top of each other, what stops you from plugging the RB interior harness to the climate control (and the climate control to some sensors) while using the origional HVAC controls to toggle where the air goes?
Wulfgang wrote:To repeat what I mentioned in another thread...
The RB ECU should work fine with your A/C. Send your thermo control amp signal to the RB ECU pin 46. Then send the signal from the ECU pin 9 to your car's A/C relay and dual/triple pressure switch. If your car has an FICD (and RB20's do not) then you will also need to connect that to your car's A/C relay.
Are there are no RB's with A/C because the wiring is too difficult or just because everyone decided to remove their A/C compressors/hoses when they did the swap?
Does anyone on this forum have a connected and charged A/C compressor on their RB engine that does not run because the wiring was too difficult???
Shane
