IanS »
https://forums.nicoclub.com/ians-u23642.html
Mon Jul 02, 2007 10:16 am
hahaha, its ok, Im a novel writer too, a noid light is a little l.e.d. with 2 pins and it fits right into the plug on the wiring harness for the injector, then you crank the engine and you can see it pulse when the ECU is telling to injector to fire. As far as multimeters go, the 10 amp should be fine, just set it to measure resistance and touch the leads to the injectors pins, resistance should be between 10 and 14 ohms. If you dont have a noid light, you can, with the engine running, take a screw driver and press the tip to the injector itself, then press your ear against the handle, you should be able to hear a clicking, check all the injectors, if one sounds differant then the others you found yourself a problem.
