boost_boy wrote:Look at the harness's plug just above the blue ecu connector and verify tat there isn't a white wire cut. Sometimes, people add those little black boxes such as an S-AFC, VPC, etc,etc. and remove them when the car is scrapped.
Dee
Is it going to be in the main Connector on the back of the ECU?
it cannot go past 2500RPMs, it is a bone stock conversion minus an air filter / downpipe, my boost gauge reads .5KPA vacuum, and also today when I was test driving it, I came back and started tinkering around and found that unplugging my #1 injector had no effect. So what I did was pull the harness and check for injector pulse (which there was) but for some reason the injector wouldn't fire, so for hours i struggled getting them out of there (breaking 1) and then I took them to an injector shop to have them cleaned and blueprinted. When I got back from the injector shop I pulled my plugs, the car is running pig rich as #2, 3, and 4, are extremely black (and have been installed for a day) where as #1 isn't nearly as bad.
Do you guys think the issue is solely fuel supply or is it aided from a malfunctioning sensor, connection etc. (I did some testing on the maf sensor and I found that there is continuity on all four wires, there is a good ground and good power)
