solaire »
https://forums.nicoclub.com/solaire-u232456.html
Tue Apr 08, 2014 9:50 am
I'm within a few days of having the car back together but I thought I'd update. I pulled the fuel rail a few days ago and found these results:
Fuel Psi: less than 5, no pressure when I took rail off after sitting for a week.
All 6 lower insulators between rail and intake were split exactly 180 degrees apart from each other.
Injector #1 OEM, Covered in fuel, Found dried up crusty fuel on inside of fuel rail around screen and O-rings, pintle at base where fuel comes out was corroded.
Injector #2 Aftermarket, Covered in fuel, pintle at top was missing and brass portion broken, cap insulator was missing.
Injector #3 Aftermarket, Covered in fuel
Injector #4 OEM, covered in fuel, crusty fuel around o-rings and filter screens.
Injector #5 Aftermarket, Firing correctly, no fuel on tip
Injector #6 OEM, black from years of dirt and oil, tip very dry as if it wasn't firing at all.
The 3 OEM injectors literally crumbled when I grabbed the top to twist them out.
