oriZnal »
https://forums.nicoclub.com/oriznal-u189708.html
Sun Apr 27, 2014 4:19 pm
hey solaire, did u get to the bottom of the problem? im having the same damn issue with my 95 300zx na.
few months back, i replaced all 6 injectors, and it ran fine for a day. next day it threw me a EGR code. I deleted the egr valve, pipes, solenoids and blocked off the vacuum lines and ports. car still runs like its missing.
pulled every ignition coil connectors out while the car was running, only #2 was dead. So i replaced with new, but still same problem. so i pulled the coil with plug, plugged, it was sparking. checked the injectors, all giving me 11~13
ohms. hooked up my modis, and saw the waveform of all 6 injectors and ignition coils, there were all working fine. checked the compression, and they all had 150~155psi. Thought my timing was off, cuz vacuum gauge was showing
lil bit of retard in timing, so took timing cover off, and checked the timing. It was on time of course. While i had it off, i checked to see if the connecting rod was bent on #2. Connecting rod was all the same from 1 2 3 and 4.
got lazy at that point and didnt check 5 and 6.
Checked the o2 sensors and b2 s1 was not responding so i thought ok let me replace it knowing it wasnt the problem, and sure it WASNT the problem haha. i took a step back and checked to see if the plenum was leaking or not
(i've had it done after i replaced the injectors) but SURE was leakin on #2 runner so i was like OK problem fixed!, past saturday i took the plenum off and replaced the gasket. i put it all back together hoping that it'll run like a
champ, but it got WORST!!!! I thought ok, did i f*** up the gasket? did it not seat right? did any of the wires get pinched? and checked my work, but it was perfectly fine, #2 runner wasnt leaking anymore, and no wires pinched
but it was BOGGING!!!!!! by then, i got sooooooooo fed up with the problem. in hand i got, 3 PTU's, 2 MAF's, 3 O2 sensors, 2 TPS', 2 extra coils, i've replaced all of them!!!! ( they are not all new. they were all used) i got 2 300zx's TT
and NA, my co-worker HAD 300zx NA so i had spare parts. WHAT THE F*** can b the problem??? there's no corrosion on connectors. **** one thing i've noticed this past saturday was, if i disconnect 1 vacuum line, just solenoid vacuum,
car actually revs little higher, and runs slightly better, but reguardless, not enough to say ok i fix the problem cuz ITS LEAKING!!!!! HELP ME PLZZZZZZZZ hahahaha ITS SO PISSING ME OFF.
I checked the fuel pressure too, 60 psi. engine codes were all same knock sensor, egr and s***... plz... somebody.... help
edit **** after the plenum was reinstalled, cylinder # 1 2 4 and 6 is not responding... but there's spark, and fuel
