Mildly Modified SR20DET List, Good or Bad?
5ForAQuarter
Car: 1991 Nissan 240sx Hatchback
I having a hard time decifering whehter or not to go SR or KA, but in the long run, IMO, I believe the SR is better. But truly, this is not about which engine is better, its about making this swap as easy as possible, and worth while.What I was going to run is as follows:SR20DET Red TopGT2871R .64 @ 15psi
Kalypso
you can pick up a 2jz block for 1600 these days............
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
Mixing engines with different shells....keep it all in the same family. With that setup you could get away with practically a stock sr drop in and upgrade the turbo, injectors, and tuning. I think the decision is truly up to you.
Kalypso
sorry my answer wasn't helpful at all.
get an sr20det its the most entertainingand most delightful motor you can buy.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
CSUPUEBLOTIM wrote:Mixing engines with different shells....keep it all in the same family. With that setup you could get away with practically a stock sr drop in and upgrade the turbo, injectors, and tuning. I think the decision is truly up to you.
Dont forget intercooler, fuel pump, and mass airflow meter. Just to make 15 psi.
Thats not mentioning things like upgraded radiator, and a full oil cooler setup if you plan to ever hit the track.
Im partial to the SR, mostly because despite what all teh KA-T boys will tell you, it does have the benefit of reliability and daily driveability.
What actually are you asking for?
Neil
Car: shooting laser guns
You can't run a 2871 at 15psi with the stock injectors, it flows much more CFM's than a T25 ever could. I'd be scared to run more than 10psi and even then I'd keep a wideband with me to make sure you're not leaning out.
If 15 psi is all you want to run, buy a new Spec-R GT28 and with the money you save buy 550cc injectors. then pony up for a MAF and rom tune to get it all running properly.
that's assuming you already understand you also need the basic stuff like a fuel pump and some sort of intercooler setup as previously mentioned.
