Midway Parts Team.com October Special
Look here for specials on Nissan parts, accessories or modifications, or tell our sponsors what you are looking for!
JedC
Well Dan, I looked at an FSM and figured everything out. The oem taper plug goes into the exhaust manifold port for the egr. I will have to get a block-off plate made using the gasket pattern for the intake manifold part of the egr. Also I was told I could use another taper plug for the aiv in the downpipe, but that's an easy fix on the welder.
I was also hoping to get parts numbers for a clutch slave cylinder, exhaust manifold gasket, and flywheel bolts for my '93 240sx. If it matters, I will be using a '98 motor with the '93 manifolds and transmission.
Thanks, you got any hats left?
MidwayParts
Vendor
Car: 2011 Titan
JedC wrote:Well Dan, I looked at an FSM and figured everything out. The oem taper plug goes into the exhaust manifold port for the egr. I will have to get a block-off plate made using the gasket pattern for the intake manifold part of the egr. Also I was told I could use another taper plug for the aiv in the downpipe, but that's an easy fix on the welder.
Will all that stuff work for a 93 or do you need different clutch stuff since its from a different year?
JedC
Everything from a '93 should work with no problems. As long as they are both ka24de, I don't think it will matter. Let me know some prices and about the hats.
MidwayParts
Vendor
Car: 2011 Titan
JedC wrote:Everything from a '93 should work with no problems. As long as they are both ka24de, I don't think it will matter. Let me know some prices and about the hats.
The Slave cylinder is $35.18 (30620-69F02)
The exhaust gaskets are $7.69 each (14036-53F01)
The flywheel bolts are $3.30 each (12315-42L11)
I still got hats. What color did you want?
LaughingBull
Car: 97 240sx
72 521
77 620
74 cb550
76 cb550
Hey Dan, need a piece not sure what it would be. Its the piece the driver side mirror is attached to that seals the front of the window. Mine is bending outward when i wash my car it lets water in. Can you find it and whats the price on the piece for a 97 240?
MidwayParts
Vendor
Car: 2011 Titan
LaughingBull wrote:Hey Dan, need a piece not sure what it would be. Its the piece the driver side mirror is attached to that seals the front of the window. Mine is bending outward when i wash my car it lets water in. Can you find it and whats the price on the piece for a 97 240?
Heres a couple of pics. Let me know if anything looks familiar.
MidwayParts
Vendor
Car: 2011 Titan
pic 2
LaughingBull
Car: 97 240sx
72 521
77 620
74 cb550
76 cb550
Gonna pull the mirror off tommorow and check it out in detail. Think it might need the whole side mirror assembly. The front part of the triangular part is warping out or was bent not sure exactly what as it was like that when i bought it.How much for the 9636 i guess, can't see the whole number?
MidwayParts
Vendor
Car: 2011 Titan
LaughingBull wrote:Gonna pull the mirror off tommorow and check it out in detail. Think it might need the whole side mirror assembly. The front part of the triangular part is warping out or was bent not sure exactly what as it was like that when i bought it.How much for the 9636 i guess, can't see the whole number?
There is a difference in whether they are painted the same as the vehicle or if they are just black. Here is the link:http://www.trademotion.com/par...gid=2
LaughingBull
Car: 97 240sx
72 521
77 620
74 cb550
76 cb550
Nice price! Mine are body colored is it prepainted or do I have to paint it? If I have to paint it do you have any aspen white paint? Sorry if these questions seem common sense, but most my car experience is with older vehicles.
MidwayParts
Vendor
Car: 2011 Titan
LaughingBull wrote:Nice price! Mine are body colored is it prepainted or do I have to paint it? If I have to paint it do you have any aspen white paint? Sorry if these questions seem common sense, but most my car experience is with older vehicles.
Its not painted, sorry. They come prep'd to paint. I dont sell the paint her but you can take your paint code down to your local paint supply store and they should be able to hook you up.
LaughingBull
Car: 97 240sx
72 521
77 620
74 cb550
76 cb550
Alright got a pic is there any way to get just this black piece? Thanks Dan for all your help on this. I'm poor and want to fix it a cheaply as possible.
KFL
Car: S14
Well I need another front sway bar endlink for a 95 240sx, (A associate bought the one I ordered needed more than me,also this would work fine for a 90 240sx front sway bar endlink?) Also need a set of sway bar bushings as well. part # still got hats.. Thanks
MidwayParts
Vendor
Car: 2011 Titan
LaughingBull wrote:Alright got a pic is there any way to get just this black piece? Thanks Dan for all your help on this. I'm poor and want to fix it a cheaply as possible.
Looks like your going to need the whole mirror. That plastic piece is molded into the mirror housing and comes as a unit. Sorry . Well, at least I can get you a great price on the mirror .
MidwayParts
Vendor
Car: 2011 Titan
KFL wrote:Well I need another front sway bar endlink for a 95 240sx, (A associate bought the one I ordered needed more than me,also this would work fine for a 90 240sx front sway bar endlink?) Also need a set of sway bar bushings as well. part # still got hats.. Thanks
Ive got about four hats left.
Here is your link for that stuff:http://www.trademotion.com/par...gid=1
onosqv
Car: '92 240sx Vert
Will the 240sx coupe car cover fit well over a 240sx w/ a body kit and wide fenders?
ralphdig
Car: S13 240SX SE - FiatSchumacher- Peugeot 307XR- Renault Alpine A110
How about these pieces do you have on stock?Front suspension, Suspension components, Lower cntrl arm, Lower cntrl arm Right 1 Front suspension, Suspension components, Lower cntrl arm, Lower cntrl arm Left 1 Steering gear and linkage, Steering gear and linkage, Outer tie rod, Outer tie rod - 4 wheel steering Front 2 Pillars rocker and floor,Gray Floor Mats - S13 240SX 1 Electrical, Antenna, Mast, Mast - Fastback, power 1.Car Cover 1, original?S13 240SX SE SHicas FastbckPlease E_Mail me ralphdig@yahoo
Modified by ralphdig at 12:30 AM 10/28/2004
Modified by ralphdig at 12:32 AM 10/28/2004
Modified by ralphdig at 1:07 AM 10/28/2004
Modified by ralphdig at 1:09 AM 10/28/2004
kane2g
Car: 92 240sx 95 240sx
kane2g wrote:bingo thats over $30
32135 Dust cover14415 4bolt turbo gasket14445 5bolt turbo gasketthose the nubmers but none are in catalog, so I just gonna call ya!
Hey dan, I ordered it this stuff, but my card didn't get charged/ didnt receive anything. Let me know whats going on.
MidwayParts
Vendor
Car: 2011 Titan
brokeAs240sx wrote:Will the 240sx coupe car cover fit well over a 240sx w/ a body kit and wide fenders?
The Tyvek (parachute material) they use is fairly flexible. I would say you would have no problem getting that over any body pieces.
MidwayParts
Vendor
Car: 2011 Titan
kane2g wrote:Hey dan, I ordered it this stuff, but my card didn't get charged/ didnt receive anything. Let me know whats going on.
I just got the last peice I was waiting for yesterday. Your card wont get charged until I have all the parts here and they are set to leave. I'll be getting you a tracking number later today. Green hat is on the way.
MidwayParts
Vendor
Car: 2011 Titan
ralphdig wrote:How about these pieces do you have on stock?Front suspension, Suspension components, Lower cntrl arm, Lower cntrl arm Right 1 Front suspension, Suspension components, Lower cntrl arm, Lower cntrl arm Left 1 Steering gear and linkage, Steering gear and linkage, Outer tie rod, Outer tie rod - 4 wheel steering Front 2 Pillars rocker and floor,Gray Floor Mats - S13 240SX 1 Electrical, Antenna, Mast, Mast - Fastback, power 1.Car Cover 1, original?S13 240SX SE SHicas FastbckPlease E_Mail me ralphdig@yahoo
Email sent. Thanks
LaughingBull
Car: 97 240sx
72 521
77 620
74 cb550
76 cb550
Theres a 97 240 in a junkyard near here gonna see if i can get the side mirror off that before i order, was also thinking bout the headliner, previous owner smoked and couldn't find the moonroof if his life depended on it. Couldn't find it on the site, how much is it? NM i found it
ralphdig
Dan when checkingout:
Error Occurred While Processing RequestError Diagnostic InformationODBC Error Code = 22005 (Error in assignment)
[Microsoft][ODBC SQL Server Driver]Invalid character value for cast specification
SQL = "sp_scUpdateShoppingCartCost"
Data Source = "PARTS"
The error occurred while processing an element with a general identifier of (CFSTOREDPROC), occupying document position (79:4) to (79:76) in the template file C:\R5\PARTS\SHOPPINGCART\_QRY\QRY_UPDATENEWPRICES.CFM.
Date/Time: 10/28/04 08:55:09Browser: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; Q312461; SV1; .NET CLR 1.1.4322)Remote Address: 148.221.84.213HTTP Referrer: http://www.trademotion.com/sho...t%3D6Query String: action=checkout&siteid=214024
MidwayParts
Vendor
Car: 2011 Titan
If you are still having problems, you can call or email your order in also. I just went on and didnt have a problem ordering.
ralphdig
Dan I place the order: Confirmation of Order 11852960.But the site always reject the gray mats I told webmaster about it.
MidwayParts
Vendor
Car: 2011 Titan
ralphdig wrote:Dan I place the order: Confirmation of Order 11852960.But the site always reject the gray mats I told webmaster about it.
Thanks for notifying the webmaster. If you want, I can just add that to your order. Oh.. and thanks for the order. I may not have any blue hats left. Is tan okay?
ralphdig
Yes please include it to the order, i would prefer to have a black hat if possible or red.Thanks Dan
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
Dan, how much for a pass. side window amplifier on a 95 s14?
sorry i haven't contacted u about any parts yet, my diff went out and its been hell trying to find another one and replace it without having a driveway etc, and yada yada yada, uggh... **sigh**
-Dan
MidwayParts
Vendor
Car: 2011 Titan
ralphdig wrote:Yes please include it to the order, i would prefer to have a black hat if possible or red.Thanks Dan
I got one red hat left. Its yours. Thanks for the order.
MidwayParts
Vendor
Car: 2011 Titan
240sx2nr95 wrote:Dan, how much for a pass. side window amplifier on a 95 s14?
-Dan
Sounds like a barrel of monkeys. Your amp is $44.28 and I have one here. Its not on the online catalog but you can swing by. I'll hook you up, Dan. Thanks
Return to “Advertisers' Marketplace!”
