Midway Parts Team.com October Special
Look here for specials on Nissan parts, accessories or modifications, or tell our sponsors what you are looking for!
gabossie
Car: Your mom
Hey Dan, just sent you my order for the differential bolts, spark plugs, cap, and rotor. Thanks.
MidwayParts
Vendor
Car: 2011 Titan
gabossie wrote:Hey Dan, just sent you my order for the differential bolts, spark plugs, cap, and rotor. Thanks.
I gots. Thanks bunches. Hat on way.
gabossie
Car: Your mom
Sweet, what color you givin me?
MidwayParts
Vendor
Car: 2011 Titan
How bout.....dark green?
gabossie
Car: Your mom
Sure. I'd take a dark blue if you have any left, or one of the white/cream colored ones. Anything will work really. THANKS
MidwayParts
Vendor
Car: 2011 Titan
gabossie wrote:Sure. I'd take a dark blue if you have any left, or one of the white/cream colored ones. Anything will work really. THANKS
Dont have any dark blue left, but I have the tan and the white.
kane2g
Car: 92 240sx 95 240sx
how about the S14 ball joints for the front.and Z32 turbo gaskets.4 and 5 bolt onesthanks
EDIT> And how about some DarkGreen hat to match my Nissan
okis14
Do you sell the fuel sock only for a S14?
MidwayParts
Vendor
Car: 2011 Titan
kane2g wrote:how about the S14 ball joints for the front.and Z32 turbo gaskets.4 and 5 bolt onesthanks
The ball joint comes with the arm. Sorry. Its here:http://www.trademotion.com/par...gid=1
The turbo gaskets are $11 and $13 each and there are four (two each). Those are not on the online catalog but you can order them in the comment area of the order.
One more dark green...... I'll hold it for you today.
MidwayParts
Vendor
Car: 2011 Titan
okis14 wrote:Do you sell the fuel sock only for a S14?
Here is that strainer:http://www.trademotion.com/par...gid=1
Thanks, and let me know if I can help anymore.
kane2g
dantech wrote:The ball joint comes with the arm. Sorry. Its here:http://www.trademotion.com/par...gid=1
Sux about the balljoints, cant afford the whole LCA.I know I will be taking one of each gaskets.But since I need to spend more $$ to get my hat.....How much is the KA dust collar on the rear of the trans?? I also will take a quick look at my 5lug swap, see if there any parts that I neef for that..... and will place the order tommorow, so plz hold the hat for 1 more day. thanks
MidwayParts
Vendor
Car: 2011 Titan
kane2g wrote:Sux about the balljoints, cant afford the whole LCA.I know I will be taking one of each gaskets.But since I need to spend more $$ to get my hat.....How much is the KA dust collar on the rear of the trans?? I also will take a quick look at my 5lug swap, see if there any parts that I neef for that..... and will place the order tommorow, so plz hold the hat for 1 more day. thanks
The rear dust cover seal is $8.26
kane2g
bingo thats over $30
32135 Dust cover14415 4bolt turbo gasket14445 5bolt turbo gasketthose the nubmers but none are in catalog, so I just gonna call ya!
MidwayParts
Vendor
Car: 2011 Titan
kane2g wrote:bingo thats over $30
Doomed2Walk
Car: 2005 Subaru Impreza WRX STi WRBP on gold
You don't happen to have the Nismo metal head gasket do you? Price?
MidwayParts
Vendor
Car: 2011 Titan
Doomed2Walk wrote:You don't happen to have the Nismo metal head gasket do you? Price?
I dont have but can order that. Its about $225It has a 87mm bore and a compression thickness of 0.5mm. The catalog says its only for the rear wheel drive Silvia.
JedC
How about the egr block off that goes in the exhaust manifold for a 93 240sx? Also anything else you'd recommend for removing egr, aiv, or emissions.
kane2g
Dan, thanks for putting the order through.It also looks like I am going to be in a market for a pair of part# 40200-0V010but thats after I get the next check........ unless you want to donate them JKunless you can?If not, JKhehehe
MidwayParts
Vendor
Car: 2011 Titan
JedC wrote:How about the egr block off that goes in the exhaust manifold for a 93 240sx? Also anything else you'd recommend for removing egr, aiv, or emissions.
The EGR passage number is 14711-40F00 and the gasket for that is 14720-40F01. Just type those in here:http://www.trademotion.com/par...gid=0
It looks like all you will need are these two parts but you may want to ask Nistech in the mechanics forum if he knows of anything else you might need. Thanks and let me know if I can help anymore.
MidwayParts
Vendor
Car: 2011 Titan
kane2g wrote:Dan, thanks for putting the order through.It also looks like I am going to be in a market for a pair of part# 40200-0V010
I have a pretty good price on those:
Doomed2Walk
How much for a S14 SR throw-out bearing?Errr KA/SR internals the same? Need a stronger or maybe just new T/O bearing
MidwayParts
Vendor
Car: 2011 Titan
Doomed2Walk wrote:How much for a S14 SR throw-out bearing?Errr KA/SR internals the same? Need a stronger or maybe just new T/O bearing
The bearing is here:http://www.trademotion.com/par...gid=1
ka/st internals are not the same number but they may work together. You will want to find someone who has switched them before to see how well that works. I would trust the original one for your vehicle.
JedC
Dan, I found the screw in plug that goes in the exhaust manifold. I don't see a manifold in the picture you put up. I searched on this topic and found the part # 14052-21R00. I believe that is the right one I need. If I read another thread right, I will also have to plug the hole coming off the block into the manifold. So the parts you listed earlier are an egr block off plate and the gasket for it? Thanks.
Modified by JedC at 12:55 PM 10/21/2004
MidwayParts
Vendor
Car: 2011 Titan
JedC wrote:Dan, I found the screw in plug that goes in the exhaust manifold. I don't see a manifold in the picture you put up. I searched on this topic and found the part # 14052-21R00. I believe that is the right one I need. If I read another thread right, I will also have to plug the hole coming off the block into the manifold. So the parts you listed earlier are an egr block off plate and the gasket for it? Thanks.
Do you have a dual exhaust? Here are some more pics. Are you just trying to block off the EGR or are you looking to replace a certain part? I dont find that number listed for your vehicle but it may be one of the things you need.
Modified by dantech at 3:09 PM 10/21/2004
Doomed2Walk
Oh one more thing, I don't know what it's called, but I need the cover for the door handle on the inside (driver's side)
MidwayParts
Vendor
Car: 2011 Titan
Doomed2Walk wrote:Oh one more thing, I don't know what it's called, but I need the cover for the door handle on the inside (driver's side)
It just makes a difference if its black or blue. Here's the link:http://www.trademotion.com/par...gid=2
Doomed2Walk
Black, also ashtray for the 95. I'm trying real hard to buy stuff to replace on my budget just to get that hat ;[
MidwayParts
Vendor
Car: 2011 Titan
Doomed2Walk wrote:Black, also ashtray for the 95. I'm trying real hard to buy stuff to replace on my budget just to get that hat ;[
This would definetly do that, by itself. Here you go:
JedC
Hey Dan,do you have any pics of the exhaust pipe right after the manifold? I went and looked at my engine today and this is where the egr hardpipe runs to. I have some questions about the parts you listed earlier, EGR passage #14711-40F00 and gasket #14720-40F01. Are these just replacement parts that I would already have, or are they specificially made to block off the egr passage? Any info on this would be great. I'm trying to get my swap done and having some trouble on this.
MidwayParts
Vendor
Car: 2011 Titan
JedC wrote:Hey Dan,do you have any pics of the exhaust pipe right after the manifold? I went and looked at my engine today and this is where the egr hardpipe runs to. I have some questions about the parts you listed earlier, EGR passage #14711-40F00 and gasket #14720-40F01. Are these just replacement parts that I would already have, or are they specificially made to block off the egr passage? Any info on this would be great. I'm trying to get my swap done and having some trouble on this.
All of the parts Ive listed are OEM factory parts that originally came with your vehicle. What is it you are trying to do? The passage is what the EGR bolts to. I took a look in my inventory and I dont see anything like a plate to block off the EGR. I asked a mechanic in my shop and he said he's heard of that being done but thinks it probably aftermarket. Heres that pic:
Return to “Advertisers' Marketplace!”
