Midway Nissan Special of the Month - May
Look here for specials on Nissan parts, accessories or modifications, or tell our sponsors what you are looking for!
MidwayParts
Vendor
Car: 2011 Titan
manchi wrote:I'm at the last step of ordering Nismo Engine mont from you guys, but at the very last step, the mug showed is not free anymore..... here's what it showed
OEM CatalogNissan Mug - May Promotion (valid only with purchase) 9.00 0.00 1 9.00
so, is the free mug promotion still available??
I was noticing that also. Ive changed it to be $.01 so when you check out, it will come out to be a penny. When I fill the order, I place it on the order but at a zero cost. Try placing it in your cart and see if it changes.
manchi
still the same. Whenever I placed check out, the mug went back to $9.00. The total price increased too. Please verify it.
MidwayParts
Vendor
Car: 2011 Titan
manchi wrote:still the same. Whenever I placed check out, the mug went back to $9.00. The total price increased too. Please verify it.
Okay, I think Ive fooled it finnally. Give it a shot now.
manchi
ok. great. Thanks for your help.
br2819
thanks for finding out about that bulb for me. i'll have to wait till next week when i can afford it.
MidwayParts
Vendor
Car: 2011 Titan
br2819 wrote:thanks for finding out about that bulb for me. i'll have to wait till next week when i can afford it.
No problem. Glad I can help.
nab911
Car: 93 Nissan 240SX SE
Is the line from the master cyl to the clutch dampener you poster earlier the same for the s13 and if not what is the part number for the s13 one?
MidwayParts
Vendor
Car: 2011 Titan
nab911 wrote:Is the line from the master cyl to the clutch dampener you poster earlier the same for the s13 and if not what is the part number for the s13 one?
The number you need is 30850-54F00
VitaminT
Car: 93 240sx SE
I placed my order today Dan. HG and some rings. Oh and a free mug.
Thanks again for all you do.
MidwayParts
Vendor
Car: 2011 Titan
VitaminT wrote:I placed my order today Dan. HG and some rings. Oh and a free mug.
I got it. Thanks and enjoy the mug.
trackslut240
Car: 1993 Nissan 240SX
Dan, i have put some of the things i am going to order from u, like the nismo power brace, which i believe is listed as OEM Catalog BRKT-TENSN RODR, i hope its the right one, i am also ordering a clutch release bearing and a pilot bushing/bearing, i need one more part and some help from you. i am trying to locate the bolts which hold stabilizer bar bushing, i couldnt find them thru the list method. maybe u can help me by some pics. thanks man. will buy more once i am employed
MidwayParts
Vendor
Car: 2011 Titan
trackslut240 wrote:Dan, i have put some of the things i am going to order from u, like the nismo power brace, which i believe is listed as OEM Catalog BRKT-TENSN RODR, i hope its the right one, i am also ordering a clutch release bearing and a pilot bushing/bearing, i need one more part and some help from you. i am trying to locate the bolts which hold stabilizer bar bushing, i couldnt find them thru the list method. maybe u can help me by some pics. thanks man. will buy more once i am employed
Fer what?
trackslut240
sorry totally forgot to tell u what car....its a 93 240sx.. ummm...i am not looking for the link for the stabilizer bar, lookin for the bolts which hold the clamp, which hold the bushing, which hold the the stabilizer bar, which is what i need, enuff whichs... also is the tied rod end boot kit a pair or a single, i need a pair, it doesnt specify but by the price i assume its a pair, then again i could be wrong... i think i will call u tomm.. my comprehension sucks and worst yet, i read it like a new person... i cant understand a word..
euston
Car: 95 240sx
i need some parts, can u please give me a price quote for sr20det's oil dip stick, oil dip stick tube, oil restrainer(oil pickup), crank pulley... all these are for SR20det s13 blacktop motor. also i need 9 studs for the turbo to exhaust manifold and the turbo to the turbo outlet...please let me know how much they costthanks
MidwayParts
Vendor
Car: 2011 Titan
The Nismo power brace is part number 54480-RSS30-US and you can do a factory number search for that here: http://www.trademotion.com/par...gid=0
The pilot bearing and the release bearing can be found here:http://www.trademotion.com/par...gid=1
The bolt for the bushing u-bracket is number 01125-01271 and you can do a factory number search online also for that.
The boots you asked about are each so you'll need to order two.
Hope this helps. Let me know if I can help with the order.
MidwayParts
Vendor
Car: 2011 Titan
euston wrote:i need some parts, can u please give me a price quote for sr20det's oil dip stick, oil dip stick tube, oil restrainer(oil pickup), crank pulley... all these are for SR20det s13 blacktop motor. also i need 9 studs for the turbo to exhaust manifold and the turbo to the turbo outlet...please let me know how much they costthanks
The dipstick is a part number 11140-53F03 and the tube guide is number 11150-53F03. You can do a number search for those here: http://www.trademotion.com/par...gid=0
The oil pickup tube can be found here:http://www.trademotion.com/par...gid=1
The crank pulley can be found here: http://www.trademotion.com/par...gid=1
The stud numbers are 14064-58Y00 and 08267-03010 and you can do a factory number search for those also.
Thanks and let me know if I can help anymore.
trackslut240
thanks for the help there dan, ok, i have one small question for the same car 93 240sx, i am ordering door hinges, driver side(left), according to my understanding, there are three pieces to the hinge, one mounts on the pillar, the other in the door and there is a pin connecting them together, i need the hinge part which mounts on the pillar, and also need the hinge pins, upper and lower, from the illustration it seems i selected the ones which mount in the door, where can i find the piece that mounts on the pillar. thanks for all the help
MidwayParts
Vendor
Car: 2011 Titan
trackslut240 wrote:thanks for the help there dan, ok, i have one small question for the same car 93 240sx, i am ordering door hinges, driver side(left), according to my understanding, there are three pieces to the hinge, one mounts on the pillar, the other in the door and there is a pin connecting them together, i need the hinge part which mounts on the pillar, and also need the hinge pins, upper and lower, from the illustration it seems i selected the ones which mount in the door, where can i find the piece that mounts on the pillar. thanks for all the help
Everyone I talk to says that if you order that door hinge, you'll get the door side, the pin, and the pillar side as a unit. I dont have one here to look at so its kinda tough to guess. There is no listing for a pillar side hinge so if they were separate, you would need to buy the pillar post to get that peice.
sXi
do you have nismo exhaust hangers? I think I will need 3 for s14 right? and the price for them please. thank you
MidwayParts
Vendor
Car: 2011 Titan
sXi wrote:do you have nismo exhaust hangers? I think I will need 3 for s14 right? and the price for them please. thank you
Sorry but I dont have a listing for those.
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
Whattup Dan?!!
Dan I know you have listed prices for timing chain kits before but I never paid atenttion and I will have to search like a million postings to find the specific post... anyway how much a complete kit for 240SX 1991 and whats included?? yes I try using the parts locator but I could not see a kit or set ......
thanks
MidwayParts
Vendor
Car: 2011 Titan
amolao wrote:Whattup Dan?!!
thanks
Hey L! Hows it goin?
Nissan really doesnt make a kit for that but I can get you a quote if you want to put together a list for me. Im not to sure what you'll need since everyone Ive sold one for has different parts they get. Like, some will order just the belt while others include an entire Overhaul gasket with everything else. Hope this helps.
kane2g
Car: 92 240sx 95 240sx
Thanks Dan, for double checking the PNs.order sent.
amolao
there you go.....feel free to post the price list on the forum...for others to use....Hey is is true that you are going to have free shipping next month?? I already have the nissan cup....
amolao
Sorry I can I get most of the prices from the parts locator but the 2 tension side bolts and the front cover oil seal, if you can provide me with the info and also if all the parts are in stock right now. If you have free shipping next month I will wait before I put the order in......
MidwayParts
Vendor
Car: 2011 Titan
kane2g wrote:Thanks Dan, for double checking the PNs.order sent.
No problem. Thank you.
MidwayParts
Vendor
Car: 2011 Titan
Hey L, what year is yours?
amolao
1991, 240SX, DOHC
ETTInnov04
Car: 1989 Nissan 240sx fastback
Hey dan I have a few ?'s for you. is there any way we could email to [email protected]
180fan
Car: 89 fastback
Dan, do you have the part numbers for:
the ATF strainer kit (auto transmission, no abs, GXE trim) for the 95 altima?
the part #'s for the nuts and bolts that hold up the tension rod brackets on the s13?
Also the nut and bolt that holds the tension rod through the bracket.
thanks Dan, btw you'll finally see my order for at least 2 (possibly 4) Nismo power braces in the next couple days...
Return to “Advertisers' Marketplace!”
