Midway Nissan Special of the Month - May
Look here for specials on Nissan parts, accessories or modifications, or tell our sponsors what you are looking for!
180fan
Car: 89 fastback
Dan, it's the EGR solenoid. It looks like a small box, behind the BPT (pictured). It's got a plug on it and two vac lines (I think?) on it.
dantech wrote:
I think what your looking for is called the BPT Valve. Its number 14741-10W00 and its about $40. Here's a pic.
MidwayParts
Vendor
Car: 2011 Titan
574-240sx wrote:Can I get a price on a coolant overflow tank(Recovery tank) for a 93 nissan 240sx. I need 2 of them.
You can find a link for those here:
http://www.trademotion.com/par...gid=2
Let me know if I can help with the order. Thanks.
MidwayParts
Vendor
Car: 2011 Titan
br2819 wrote:ok this is all the writing on the base of the bulb:D2R 35W 85126O3U DOT G317
this is how it was written on the bulb.
Well.. I did some checking in my inventory and most of the bulbs I have from Nissan are Sylvania. I dont have a conversion chart for the Phillips to Nissan so I would have to go by Model and Year. Is there any indication of what Nissan that came out of?
onosqv
Car: '92 240sx Vert
nissan 240sx 89 auto coupe
injector o-ring (insulator top & bottom) part # for ca18det injectors first please.
Also, part #'s for the sohc injector o-rings (insulator top & bottom)
Thanks a lot.
MidwayParts
Vendor
Car: 2011 Titan
brokeAs240sx wrote:nissan 240sx 89 auto coupe
Thanks a lot.
Heres a quote with all of those numbers.
br2819
i have no idea would a pic help? i bought it for my accord and now one of the bulbs is out so need to find out exactly what kind it is.
MidwayParts
Vendor
Car: 2011 Titan
br2819 wrote:i have no idea would a pic help? i bought it for my accord and now one of the bulbs is out so need to find out exactly what kind it is.
A pic might help. Maybe that'll give me a better idea of what your looking for.
br2819
heres a pic sorry its so blurry
blu240hch
Car: 1991 Nissan 240SX
Dan, I need a replacement mid/woofer, front door location, for a 95' 240sx component system. any chance of scoring one? I really don't feel like purchasing a full component set, when I only need one speaker.
thanks,B
MidwayParts
Vendor
Car: 2011 Titan
blu240hch wrote:Dan, I need a replacement mid/woofer, front door location, for a 95' 240sx component system. any chance of scoring one? I really don't feel like purchasing a full component set, when I only need one speaker.
thanks,B
Yep, heres a link:http://www.trademotion.com/par...gid=2
I guess there is a difference for w/cd or wo/cd. Just click on the left menu name "speaker" and you'll see what I mean.
MidwayParts
Vendor
Car: 2011 Titan
I think I found one thanks to my illustrious parts manager. It was in the Infiniti section. Not sure what it fits but heres a pic. It has all of the numbers you posted on it so I think we're golden.
blu240hch
Sweet! I've got the cd player, so I guess it'll be the cheaper of the two.Just placed the order, along with a sunroof weather stripping kit. Told you I'd be ordering more stuff sooner than I thought!
Thanks
MidwayParts
Vendor
Car: 2011 Titan
blu240hch wrote:Sweet! I've got the cd player, so I guess it'll be the cheaper of the two.Just placed the order, along with a sunroof weather stripping kit. Told you I'd be ordering more stuff sooner than I thought!
Thanks
Thank you for the order. Mug is on the way.
kane2g
Car: 92 240sx 95 240sx
Hey dan, 90 NA 300ZX calipers 26mm;)there are all sorts of pins and bracketry and stuff that is needed.26mm Pad Pins - 41217-30P00 needed 4?Pad Pin Clip - 41218-30P00 needed 2?26mm Spring Clips - 41090-30P01 need 2?
I need them for both sides So is there any other pieces I need or is that all?I already got the calipers/pads.LMK so I can order all of it at the same time.
MidwayParts
Vendor
Car: 2011 Titan
kane2g wrote:Hey dan, 90 NA 300ZX calipers 26mm;)there are all sorts of pins and bracketry and stuff that is needed.26mm Pad Pins - 41217-30P00 needed 4?Pad Pin Clip - 41218-30P00 needed 2?26mm Spring Clips - 41090-30P01 need 2?
Well ive attached a pic so you can see, broken down, what the caliper looks like. You may find things that are worn once you take it apart but there are no other listed fixes that you would need. All of the numbers you've listed can be typed into my factory number search area here: http://www.trademotion.com/par...gid=0
kane2g
by the looks of that pic, I got the quanities right. So I will be ordering this as soon as I get my check
MidwayParts
Vendor
Car: 2011 Titan
kane2g
Hey dan, I just fukked my clutch hardline.one from master cylinder to the dampner as shown in the pic
But mine is for a 92 non ABS 5speed fastbacknot 95 like the pic. Is the PN the same or different???
and give me like 3 of those clips that are on the firewall that keep the lines togehter.
Modified by kane2g at 7:50 PM 5/12/2005
br2819
yes that is the same bulb. now heres the scary part how much is it?
MidwayParts
Vendor
Car: 2011 Titan
kane2g wrote:Hey dan, I just fukked my clutch hardline.one from master cylinder to the dampner as shown in the pic
They are different. The pipe is number 30850-40F00 and the clip is number 49791-94L00. You can do a number search for those here: http://www.trademotion.com/par...gid=0
MidwayParts
Vendor
Car: 2011 Titan
br2819 wrote:yes that is the same bulb. now heres the scary part how much is it?
$172.36
Did you need some help off the floor? Well...at least you wont have to pay full list which is $215.45
br2819
jeeeeezus ok now how do i order? i better have a mug with it too.
nab911
Car: 93 Nissan 240SX SE
How about the Hardline from the clutch master cyl to the slave cyl on a 93 240sx?
MidwayParts
Vendor
Car: 2011 Titan
br2819 wrote:jeeeeezus ok now how do i order? i better have a mug with it too.
Just go here:http://www.trademotion.com/par...gid=0and do a factory number search for number 26297-89910 and select Infiniti. Then add it to your cart and your all set to go.
nab911
Dan, is the first hydraulic clutch line listed under 240 the one im thinking of? i need the ~6 foot line from the master cyl all the way down to the slave.
MidwayParts
Vendor
Car: 2011 Titan
nab911 wrote:How about the Hardline from the clutch master cyl to the slave cyl on a 93 240sx?
You can find that here:http://www.trademotion.com/par...gid=1
MidwayParts
Vendor
Car: 2011 Titan
nab911 wrote:Dan, is the first hydraulic clutch line listed under 240 the one im thinking of? i need the ~6 foot line from the master cyl all the way down to the slave.
Maybe this pic of the 93 will help.
nab911
The part i need is the 30650 one from the pic but i typed that in on the site and it didnt pull. Is this the right one from the site "HYDRAULIC LINES, 240SX, Tube, From Connector To Hose"?
MidwayParts
Vendor
Car: 2011 Titan
nab911 wrote:The part i need is the 30650 one from the pic but i typed that in on the site and it didnt pull. Is this the right one from the site "HYDRAULIC LINES, 240SX, Tube, From Connector To Hose"?
An easier way would be to go here:http://www.trademotion.com/par...gid=0
and do a factory number search of part number 30850-54F00. Then add it to your cart. You wanted the one for the 93, right?
manchi
I'm at the last step of ordering Nismo Engine mont from you guys, but at the very last step, the mug showed is not free anymore..... here's what it showed
OEM CatalogNissan Mug - May Promotion (valid only with purchase) 9.00 0.00 1 9.00
so, is the free mug promotion still available??
Return to “Advertisers' Marketplace!”
