If the studs/nuts get loose they will rattle around and eventually falloff or worse , break. You should use a Stover style locknut (it looks oval in shape as it is literally squeezed to deform the nut for a never-let-go fitment). No loctite will hold up past 1500 degrees and your manifold can easily surpass this if doing an extended drift day or drag event. You can try Sleeve retainer however it is the highest grade of loctite available and is green in color but 9 times out of 10 you will never, ever get the nut off after a sleeve retainer application and you have to break the stud/bolt to remove it.HPR wrote:I have an aftermarket manifold too (silk road) and mine came with studs on all 4 corners with the nut being on the turbo side. I too am experiencing massive exhaust leak.
After further inspection and pulling out the manifold and turbo. I noticed that 3 of th 4 studs snapped in half!
