Megan Coils and CV7s
goat35
Car: 2013 M35H
2008 G35 Sedan
I don't post much but I have a 2012 M35H
33k runs great no issues but needs some TLC
front end needs to be repainted due to rock chips
Moving on
I have my CV7s got them used and pray they have no issues .
All are 20x10.5 +27
I feel that the tires may be too thin 255/30/20 and 275/30/20
Also I got some megan coilovers (I know....) but they were free from a friend who runs a shop out in Florida
I think tomorrow I'm going to make the dive and start the install
1st time ever installing coilovers so any tips, tricks, and pointers are highly appreciated. Ill take pics and post them as I go.
Also if anything sounds like it may be a problem don't hesitate to reply this is my daily driver!
Ilya
You can use my guide on the suspension from the Y50 forum...(see sig)...should be pretty much identical except for maybe the rear.
wideopn11
Car: 2012 Infiniti M37x Moonlight White
Takeda CAI
Stillen exhaust w/ MeganRacing Y-pipe
SCALE coilovers 16K/10K F/R
Akebono BBK
Cusco strutbar
25mm spacers F/R
Uprev tune by seymore4
Ilya wrote:You can use my guide on the suspension from the Y50 forum...(see sig)...should be pretty much identical except for maybe the rear.
I think the 2012+ guide might be more applicable.
how-to-2011-m37x-eibach-install-diy-t576774.html
Ilya
Oops, forgot you wrote one when you lowered :gapteeth:
goat35
Car: 2013 M35H
2008 G35 Sedan
Thanks guys this will really help. Weather has me held up for now.
goat35
Car: 2013 M35H
2008 G35 Sedan
Trouble
Rears went in today. First 1 took 2 hours (hard fighting that strut off) Second took 20 mins. I find after removing bottom bolt using two screwdrives on each side and prying the strut off worked very very well. Also i had a 3ft 2x6 plank I wedge in to manipulate the control arm when needed.
Then I moved to the front. Setup everything and got tires and lines pulled off. WHY is it so hard to break the linkage on the strut and sway bar. I tried for 30 mins then had to take the wife to NYE party. I think I may need an impact... Ill try using a torque multiplier/mechanical advantage tool ( a 18" breaker bar with a jack pipe) and if that doesn't work well im stuck looking for an electric impact.
I really hope it can put out enough anyway.
Any tips or tick would be gold right now
Anyway Happy New Year all!
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
Penetrating oil and impact driver if you can get your hands on one. Sometimes nuts and bolts are just a PIA. I had to cut one off when I installed my exhaust and halfway rounded a nut installing my strut bar and had to replace the nut. :gotme
goat35
Car: 2013 M35H
2008 G35 Sedan
Bad new
Today I got a 300ft impact wrench and the rest is history.
5 mins into it the nut stripped!
FML lol going to put everything back on and take it somewhere to get the fronts installed. I was almost there!
goat35
Car: 2013 M35H
2008 G35 Sedan
Good news
buddy came over with an extractor set and we got it off.
Swapping fronts now and will be done with that.
Sent lug nuts to old address so the wheels will wait for now.
Ilya
Nice, bet you're excited lol.
goat35
Car: 2013 M35H
2008 G35 Sedan
Yeah I'm stupid stoked and pretty proud! Waiting for some lug nuts and probably gonna have to splurge on some new tires for the vossens. The current ones are from the Z and 30 series tire really scared me. so looking to upgrade the dome lights and start saving for the next big item.
