i think it had a hint of ATFsuperuber wrote:It smells like GM top cleaner but tastes like Chevron Techron!
WHAT????? He just charged me $18maxnix wrote:BG44K is crack of fuel system cleaners.
Did you see a glass pipe near his tool bench?
BG44K $8 + shipping form Joe last month special!
yeah because he ran out of the special within like 2 days of starting it.Q_SHIP wrote:WHAT????? He just charged me $18
I was actually going to post that up.... "Ill have a Gin and 44k with a twist of lemon"66mgb wrote:I think it's best on the rocks with a twist of lemon.
Another Q savedPeterofdevon wrote:OMG
Thanks to today's posts I just put a can in the Blue Q and within 30 seconds the injector opened up. I may pull the Ebay auction, I'll certainlly revise it.
ITS MIRICLE STUFF!
Peter
Nothing like a laugh of amazment after Bg44k "fixes" another problem on the Q.Peterofdevon wrote:OMG
ITS MIRICLE STUFF!
Peter
I love IT. 65 cans!!!Q45tech wrote:A can every 90 days a few days prior to oil change keeps oem injectors as good as they can be with 311,000 miles and probably 65 cans consummed.
If I knew about the $8 a can sale you guys woulda been knocked DOWN if you were ahead me in line YAAA.
The BMW dealer parts guy on the phone was very reluctant to sell it to me. He wimpered that they only had a little left. I pleaded for two cans--- it was like buying dope!!!!
When I went to pick them up some other dude was on the counter...I said I'm here for my 4 cans .
I don't even want to start the Green Q until I put it in!!!
Its dope.
Peter
If you can...try to use Tier one gas...Shell, Chevron. Every pump near me says "contains ethenal.Q45tech wrote:THAT IT WORKS AT ALL PROVES HOW BAD the product called premium gasoline really is!
16 years x 4 per year equal 64................We have a tech who buys 24 cans from the BG VAN he gives them away at Xmas his car, wifes, parents......with 6 cars to feed it goes quick.
Does the oil change have anything to do with the use of the BG44 or is this simply a way to gauge how often it should be used?maxnix wrote:Just in the last tank before every oil change.
Serious industrial qulaity sovents can contaminate your crankcase, so best done and then have fresh oil in the crankcase until next time.Peterofdevon wrote:Does the oil change have anything to do with the use of the BG44 or is this simply a way to gauge how often it should be used?
Peter
What do you think spraying such a severe solvent does for your cylinder wall lubrication?elwesso wrote:i really doubt that using BG44k in the middle of your OCI vs at the end makes any sort of measurable difference,..
That's why u do cleaning procedures just before oil change!Cheers!maxnix wrote:Serious industrial qulaity sovents can contaminate your crankcase, so best done and then have fresh oil in the crankcase until next time.
