MBC, Not what you think
ser2102
Car: 91 dead. 90 getting did
so i have a HKS manual boost controller. today i test drove the car, tinkered with it to get the idle right, the SAFC right, the BOV right and the MBC.
well the first couple times i got on it, i was hitting 15psi. YIKES!! and that was with the MBC turned all the way down, so the psi should have been at ~7-8. after a while the car went down to about 6 and stayed there consistenly. no matter how much i close up the MBC, the psi is at about 8 now. should be higher dont you guys think?
im using the large nipple on the throttle body to feed the BOV and MBC. i dont think thats too much?
help!
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
the MBC should be fed by a Direct boost source, not MAP. using MAP is a good way to destroy your wastegate actuator.
fc3sdrifter121
is it a ball and springs mbc, or bleeder valve?I didnt have much luck with a bleeder valve style on my mk3 supra,but I had a "quality" ball and spring one that worked great
IanS
HKS adjustable wastegate actuator FTW
ser2102
hmm i see, but i have no other sources to really plug into for the actuator.
Im not sure if it is a ball and spring, but i would have to guess that it is.
